15K no transmission fluid change--void warranty?
#31
Originally posted by flipside909
It actually takes more than 4 quarts of tranny fluid to entirely drain and refill it. It's more like 6-8 quarts including whats in the t/c.
#32
Super Moderator
Flipside,
I agree with you about the flush and the drain-and-fill. I have been flushing every 30K, and doing the drain and fill on the 15K. Excellent performance. The last Lexus dealership I went to DID FLUSHES. My fluid was also silvery/powdery and performance improved big time after the flush and that was over 10K miles ago.
#33
Lexus Connoisseur
For the 60k or greater fluid change fans and non belivers...here's some proof w/DIY info on what a typical fluid change involves..and an approximation of how much fluid is left from just a simple drain/refill. Sure it's not the tranny in the RX, but it should provide insight.
http://lexusmodz.netfirms.com/GS_DIY...il/index1.html
Good luck!
Good luck!
WhatYaGot
01-07-08 05:00 PM
PlayboyzGS
Maintenance
27
02-14-04 11:52 PM
car, change, changed, changing, fluid, flush, flushing, maintainence, preventive, toyota, transmission, void, voids, warranty, warrenty
