User RX 300??
I'm considering getting a used RX300. Are all years RX300 pretty much the same? If not, what are the major differances?
What are problem areas to look for on a used RX300?
What about 2wd vs 4wd? I don't get a lot of snow, so if the 2wd had the same traction as my fwd Camry and ES300, that would be sufficient. Could I expect a 2wd RX to do as well in tha snow as my ES300?
How are most RX300s equipped, 2 or 4wd? Any special maintenance issues with 4wd? I heard that all wheel drive Suberus self distruct unless tires are perfectly matched. Same for the RX?
What do you think about the Lexus pre-owned certification, is it worth the bucks? Thanks
If you go here http://www.lexus.com/cpo/model_library.html It will tell you specifically what are the differences and what has been added to each of the year.
Good luck in finding your RX300. You'll really like it a lot it's a good vehicle.
![Wiggle](https://www.clublexus.com/forums/images/smilies/wiggle.gif)
-Robert
Compaq
RX - 1st Gen (1999-2003)
16
02-20-03 01:34 PM
