RX 300 Idle Speed
My wife's 2000 RX 300 [ 48,000 miles ] seems to have a higher than normal cold-idle speed. On a 60 degree morning [ in the garage ] it has been idling at about 1750 RPM when first starting up. After a few minutes it slowly goes back down to idle speed [ about 500-600 RPM ]. Is 1750 RPM normal for 60 degrees or am I being too picky? This will be the 2nd cold-season with the car; don't remember this high of an idle-speed.
Out of Warranty
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
1750 does seem awfully high - the ECM may be getting bad information, or you could simply have a cable or linkage getting stiff in cold weather. Whatever the cause, shifting into reverse at 1750 won't be doing the transmission any good. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
You are far better versed in diagnosis and repair than I, but about all I can contribute is that kind of "idle" speed is abnormal for the RX. My '00 300 did idle fast under somewhat colder condtions . . . well, as cold as it gets down here in the tropical prairie - 40's or so . . . . but it rapidly slowed to about 1100-1200 after no more than 10-15 seconds. I know this may date both of us, but I instinctively gave the throttle a blip to "get it off the fast-idle cam" (remember carburetors?) and it seemed to work. . . .maybe a bound cable?
I caught myself trying to do that to my 330 a time or two last winter. Felt really stupid when I realized that only electrons connected my right foot to the 3.3L ECM.
