99 Rx300 Misfire Help!!
Originally Posted by Lexmex
JP...I have also had friends with other cars who show multiple misfires...yet only one coil is the problem. On the night I had my coil mess up, I also showed misfire in cylinder 1. We checked that one and it was fine turns out it was only one that I had to replace in the end.
JPI
Super Moderator
Originally Posted by JPI
You have to know the RX300 is a little bit different. It has the individual coil. I'm not a big fan of swapping parts. Find the problem and then fix it. Your long and short fuel trim will tell you.
JPI
JPI
I took my 99 rx300 with 100k to IRA lexus in Ma for rear brakes change. After driving out of the dealer parking lot, the check engine light comes on and the car was trembling. I was furious and have a mindset that the technician might do someting to the car. It is strange because the car was fine before bringing it to service for brakes. My question is "What are the symptoms of an engine coil being broken?" The only thing I can think of is that they might disassemble the battery and reset the brake light cause the brake light was on. I might be wrong. I just don't trust IRA lexus technicians anymore.
JPI
Super Moderator
I replaced my Camry coil to the regular RX coil last night and the car runs somewhat smoother and not as loud. However, the Camry coil worked when I needed it.
Originally Posted by mikey00
There is a small chance that something like the MAF failed while they were doing your brakes and as mentioned it's really not there fault if it did. I believe there is a much greater chance that while servicing your car they did other rountine checks and caused the CEL. A common one is that when they check the air filter, they lift up the top of the air box and disconnect the hose behind it where it connects to the metal tube below. This is located directly under brake fluid container.
JPI
OK, I've read through this thread and I honestly can't make heads-or-tails out of most of it.
My '99 RX300 is getting (consistently) a P0305 code, which says that cylinder 5 is misfiring. I can feel in running rough. So, I figured - what the heck, put in some new spark plugs and see if that fixes it up. Of course, to get to the back cylinders, you have to take the entire damn top of the engine apart (air scoop, throttle, etc.), but I was able to handle all of that.
I got in all the new spark plugs, and (just in case), moved the ignition coil from the front-right cylinder to the back middle cylinder (assuming that cylinder 5 is the back-middle cylinder - or at worst, the front center cylinder). No joy!
I still get the P0305 code, still runs rough.
So, I have 2 questions: 1) which cylinder is #5? (Please - oh _PLEASE_ tell me it's at least the one on the right side if it's still in the back); and 2) what else could be causing a misfire on a specific cylinder? (Please try not to use too many acronyms and jargon, I'm new to "modern" cars... I could disassemble a carb, or even replace a head gasket on my old cars, but the new stuff is still "magic" to me.)
JPI
i just had my timing belt done and two days after I got my truck back ... I started to experience a cylinder misfiring problem. So i took into Lexus and at first they check the air flow meter but it was fine and then they were going to try replacing the P1135 air/fuel ratio sensor to correct the 1/3/5 misfire in bank 1 ... now they're telling me that they took off the cover and performed a vacuum test and confirmed a low steady reading of 15-16 ... should be around 19 ... this low reading would indicate retarded timing ... they went further to say that they suspect that the rear cam is out by 1 tooth and that they recommend to remove the belt and re-align at a cost of approximately $500 - help!!! I'm not sure if they're being honest in their diagnosis or just capitalizing on an opportunity to squeeze me for more money! If anyone can help, I would really appreciate the input.
Super Moderator
Most of the time the inexperience will miss a tooth in the rear when doing timing belt service on this vehicle. What is the code?
JPI
snorander
RX - 1st Gen (1999-2003)
08-06-15 11:20 AM
Jacklalane
39
06-28-15 03:37 AM
ZeekGS300
11-28-11 07:26 AM
