Who tows with their RX?
Old 05-12-01, 04:39 PM
DaleA
Guest
Posts: n/a
Hello everyone. I am considering a RX300 and just found this board today. I am curious if anyone has experience towing with their RX. I have a 17' fiberglass boat, probably about 2000 lbs total that I will be towing. Does the RX handle the load well - does the rear end sag, can it keep speed up hills?
Thanks, Dale
Old 05-12-01, 09:30 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
There is tongue weight restriction and then there is towing weight restriction. Check the user manual.
Salim
Old 05-14-01, 10:04 AM
Kichgai
Guest
Posts: n/a
I put 30 80lb bags of gravel in the back once on a short trip from Home Depot once. Talk about a low rider...
I also have been towing about 1000-2000 lbs of building materials on a 60 mile drive for our weekend retreat on curving roads. The back sways a bit excessive (IMHO) compared to a truck as you would expect. It does sag like a boat a much since the weight of the tow is balance on the axle, compared to typical boats trailers.
But going up the hills (10% grade a mile on average at times) its got the power (wish it had a turbocharger) so that no one will laugh with you on your lack of power.
Kichigai
Old 05-22-01, 10:07 PM
2ndRX300
Guest
Posts: n/a
Yep! We tow a pop-up trailer (2200 lbs) with ours and it rides great. Gas mileage goes down to about 16. The tow max is 3500 lbs and as a rule, we're only supposed to tow 75% of that.
Boomin
02-16-20 02:13 PM
goodduck
RX - 4th Gen (2016-2022)
05-29-17 08:25 AM
salimshah
03-15-08 09:36 AM
tdloftin
10-24-01 04:16 PM
Quick Reply: Who tows with their RX?
