Irridium Spark Plugs
Local Toyota Dealer's service department wants $169.95 plus taxes to replace 6 irridiumm spark plugs on my 1999 RX300.
Also, they want $239.95 plus taxes to change the timing belt and $45.00 plus taxes for exterior belt.
Another Toyota dealer quoted a price of $269.95 plus taxes to change the timing belt and $60.00 for exterior belt. Irridium Spark Plugs were quoted $13.00 each plus labor and didn't say how much for labor.
At that rate six plugs would cost $78.00 and first dealer would be charging $91.95 labor which sounds a little steep.
Second dealer also told me the Lexus belt cost more money than the Toyota belt. When I mentioned they both had the same part number they were unaware of it. Claimed they didn't know the engine in the 1999 RX300 was same engine as in the Toyota Highlander. That's hard to believe.
GCrim21
GCrim21
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Was the price for the Iridium plugs the same if it was a V6 Camry/Highlander? Yes as you mentioned they are the exact same engine. I just got a 2005 NGK spark plug catalogue with cross references for all other plug makers (including Denso) with part numbers. If you know the correct part numbers for the Denso & NGK (Toyota / Lexus uses either or) you might be able to locate them at a regular auto parts store for less money. Do you have a good independent mechanic you can take your vehicle to get the work done?
gc, did you make a decision on your tires (I assume you got my reply PM)?
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Originally Posted by HarrierAWD
Dealership price is always higher than independent shops. Those prices (parts & labor) are actually very good IMO.
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Lexus Connoisseur
yes they should be the same,
SK20 - OEM Denso Iridium
IK20 - Denso Hi Power Performance Iridium
PK20 - OEM Denso Platinum
Lexus Connoisseur
Also, the rear bank is the hardest part to get on the 1MZ/3MZ which explains why the labor hours drive up the price. The front 3 plugs are cake, the rear is not fun.
The high power Denso's I don't think last as long as OEM iridiums.......the hi power I think are good for only 30,000 miles. Correct me if I'm wrong flip.
Lexus Connoisseur
I'll double check my NGK catalogue later on just to confirm. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
That's correct the hi-powers are performance plugs so the lifespan is much shorter than the OEM iridiums.
GCrim21
GCrim21
Ok, directly from the latest 2005 NGK spark plug catalogue with cross reference numbers for the Denso as well. OEM iridium spark plugs for 1999 RX 300 are as follows: (same part numbers also apply to the ES 300 as it's the same engine).
- OEM original equipment iridium NGK (laser iridium) part # IFR6T-11 - (NGK stock # 4589 ) gap - .044
- Denso original equipment iridium part # SK20R11 gap - .44
These numbers should be on the actual spark plug of their respected makers.
These are the long lasting ones.......there are other iridiums from both NGK (IX series) & Denso (IK series), but they will not last as long (good for 30,000 miles to 50,000 miles as compared to 100,000 miles + with the OEM numbers I have given above). I hope this helps & Good Luck!
Thanks Lexusfreak, HarrierAWS, flipside909, and jeremyp111 for your responses.
No Lexusfreak I haven't purchased any tires yet and I haven't read your PM. I will do that and thanks for your recommendations and suggestions.
I have decided not to change the irridium spark plugs that came from the factory in my 1999 RX300. I was going to change them because of what the owner's manual said. The 1999 Lexus Owner's Manual Supplement in the Scheduled Maintenance Log Book that came with the RX said to replace the spark plugs at 90,000 miles. Not long after I bought the RX, I received an 'updated' Supplement Manual and it says to replace the spark plugs at 60,000 miles. I had been told by one Lexus service rep to replace them at 90,000 miles that they didn't require replacing at 60,000.
The reason I had mentioned replacing them at 90,000 miles was I had talked to a Toyota dealer's service manager about replacing the timing belt and water pump and he told me I should replace the irridium plugs at 90,000 miles because the engine and drivetrain are identical to the Toyota Highlander and the "official Highlander manual" says replace them at 90,000. Yesterday I was talking to another Lexus dealer's rep and he showed me in the "official service manual for 1998-2003 RX300" that the irridium spark plugs did not have to be replaced until 120,000 miles unless a problem had developed because of the spark plugs. He said it is a waste of money to replace them less than 120,000 and advised against replacing them. I was a little surprised at him showing me the manual and saying that. However, he is the same service rep who quoted me $1,200.00 to replace the timing belt with related parts and water pump.
Right now a local independent garage owner whom I trust is getting prices for the parts and he is checking prices from Lexus dealer's and Toyota dealer;s for best pricing. He has and does repairs and replacements on Lexus vehicles. My wife had a Toyota Avalon that developed a power steering leak at 71,000 miles. We were told at the Toyota dealer it would cost $971.00 to 'fix' it. By 'fix it' the service rep meant replacing the rack and pinion steering box. I had the local independent garage owner do the work and he charged $582.00 to do the job. I asked him where he got the unit and he said from 'the' Toyota dealer. The same dealer that had quoted me $389.00 more for the same work!
A side note: I asked the Toyota dealer service rep why did the whole power steering box have to be replaced in order to repair a leak and he told me because it was a sealed unit. I then asked him if it was a sealed unit, then why is it leaking? "Couldn't be sealed if it is puddling fluid on the garage floor". He said ..... 'all I know that it is a sealed unit and has to be replaced to stop the leak'.
I realize all dealer's push their service departments to sell services for more revenue. Some push more than other's.
It's always better to take the vehicle to a mechanic you trust.
gc, if you have anymore questions about tires after you get my PM, feel free to ask.
Lexus Connoisseur
