Engine "sludged"; needs replaced at 62k
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
First of all, thanks for the great info on this forum. Lots of good info here for our wonderful vehicles. That said:
Well, first bad experience with my 99 rx300. Yesterday the oil light came on while driving followed shortly by the check engine light. Then the car shut off on me - once while driving at about 20 mph - and at 3 traffic lights. Engine sounded like it had half the oil it was supposed to.
I was literally 3 miles from the delaership so I slowly made my way there. Service manager informed me that my engine had become "sludged" due to previous owner's (leasee) failure to change the oil at decent intervals. I've had it from 40k til now with no problems. Surprisingly, the new engine will be done under warranty, no cost to me. Actually, a new engine at 60k doesnt sound too bad to me. Anything I should watch out for or be aware of?
thanks again to all
thanks again to all
![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
Lexus Connoisseur
Wow. sorry about your unfortunate situation. But kudos to Lexus for finding you a solution. Just take it easy for the first few thousand miles for the seals to seat properly. Then you'll be good to go for a long time. Just be sure to change your oil at regular intervals and you will be perfectly fine. I have had 2 1MZ-FE V6's in two different cars that have had no sludge problems. one is a 95 Avalon that I got rid of at 105k. and currently a 99 Solara SE V6 Manual at 96k. All are sludge free.
Welcome to CL!
Welcome to CL!
thanks for the tips on the break-in period.
The Service manager is a friend of mine but I dont think i got special treatment here. He said for a while he was replacing up to 5 a month. Most recent was a woman with an 02 LS who went nearly 18,000 miles without an oil change. Engine failed and he had a used engine prepared to sell her. Lexus called and said new engine at no cost (warranty) with no questions asked. Can't beat the service for sure but I think it kind of sucks that someone can just abuse the vehicle with no repercussions or money out of their pocket.
My BIGGEST fear is that I will have tranny problems just after my warranty expires. Although I have no reason to think that I would except for some of the experiences on this forum. Fingers crossed...warranty expires at 70k, correct? Maybe I should have them thoroughly inspect the tranny while it is in and my friend is in charge?
Sorry to hear about the sludge problem. Glad that the dealership is treating you well.
This is the 3rd case of RX300 sludge problem that I've read here. In all 3 cases, it was used RXs, not original owners.
Just break in the new engine as you would with any new car. Then change oil every 5,000 miles. Enjoy the new engine.
Lexus Connoisseur
Originally Posted by StrmRdr23
is there a way to check if there's a sludge build up? would they detect it when the mechanics are doing the oil change?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
thanks again to all![Big Thumb Up](https://www.clublexus.com/forums/images/smilies/biggthumpup.gif)
thanks again to all
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Originally Posted by flipside909
When you startup your vehicle and during normal idle, there's a constant white/bluish cloud that is emitted from your exhaust. If you see a white cloud at startup but disappears, that's just initial water vapor from cold startups, you have nothing to worry about.
Originally Posted by Lexusfreak
How often did the previous owner do his / her oil changes? Did you get service records before you purchased the vehicle? ![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
Just break in the new engine as you would with any new car. Then change oil every 5,000 miles. Enjoy the new engine.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Originally Posted by LexusLuver
Isn't it 3months, 3000mi?
Didn't get the records. I also mad eanother goof by not having it certified. I was being a cheapo and they hadn't done it yet ($900) so I just said skip it. Turns out they would have put new tires, brakes, etc on it which I ended up needing to do myself. Also, car would have been warrantied til 100,000. I havent had any problems but I do worry a bit about my tranny aftre reading some of the "just out of warranty" problems on this forum. Fingers crossed...
It's nice that you are getting a new engine, but that currently is Toyota / Lexus policy on the sludge problems for this engine...the 3.0 L V6. Toyota now warrants the engine for up to eight years in some cases depending on year and original delivery date AND......here's the nice part.....will either rebuild, remanufacture, or replace the engine if the current owner can give documentation of at least one oil change in the last 12 months with the proper grade oil and filter. If an owner buys the used car from a dealership and the engine siezes up within that year, then of course it is dealer fault since dealers routinely change oil and filters on every used car in their lot...especially Certified Used Cars. Now, if it is purchased from a private owner and you own it less than a year and it siezes up, my understanding of this (not necessarily a fact) is that consideration is made if the previous owner did not change the oil at reasonable intervals......as in your case. And...in your case.....you won out. You get a new engine.
Treat your new engine as you would a brand-new car. If you don't know the standard break-in rules PM me and I'll give them to you.
Good luck.
Good luck.
Good luck.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Good luck.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek2.gif)
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
