Any DIY Instructions for Transfer Case Fluid Change?
Originally Posted by TunedRX300
Rotating the right rear wheel worked, I applied some WD40 and used a L shaped 10mm Allen. With 53K miles, gear oil has become black with fine metal debris near the drain plug. Oil near the fill plug looks OK - light yellow. Thanks for the tip.
I isn't as ugly a job as one might think... Just remember to loosen the fill plugs first, to insure you can, then the bottom drain plugs.. I also had to lower my jack slightly to level the RX prior to filling the Transfer and Rear Differential units... Thanks for the appreciation and your remarks...
Organized Garage Status
GX - 1st Gen (2003-2009)
04-11-18 09:13 AM
runningox
04-05-09 08:10 AM
jonathancl
06-18-05 09:16 AM
