Wheel lug torque?
I remember reading some time back, about incorrect wheel lug torque creating warped rotors. Who knows the correct torque for stock alloy rims? Firestone had them torqued to 150ftlb. that can't be good. I backed them off to 80ftlb., but would like the factory figures.
Thanks
Thanks
Thanks
Thanks
Whoever tightened them to 150ft-lbs should be fired; I don't know of a single passenger car/light truck that requires that much. I think the Mercedes M-class is the highest at 110 or something in that neighborhood.
I agree on 76 Ft Lbs for wheel lug torque for both factory alloy and chrome wheels. I also lubricate the threads with a little dab of grease, say LubiPlate Lithium white. But, personally, mine are at 75 Ft Lb as it is a easier number to remember...
Thanks for the replys. I'll have to take a good look at the rims to make sure they didn't crack. It took every bit of my strength and a 2 foot long torque wrench to break the lugs loose. I'm 190lbs. Anything I should look for besides cracks?
Service manual states 76ft-lbs
Stay away from grease, unless it is for high temp. The right product is anit-cease compound.
I torque the keyed-lug the last and un-thread it first.
Salim
Salim
Out of Warranty
Originally Posted by TunedRX300
Stay away from shops that use impact wrenches. A good shop uses torque wrench to hand tighten lug nuts.
If you were a NASCAR fan, you'd see the Unocal #76 orange ball all over the place.
