View Poll Results: when you open your gas cap does it make a sound of pressure being released?
yes
29
54.72%
no
24
45.28%
Voters: 53. You may not vote on this poll
Gas tank pressure poll
Old 03-20-05, 05:50 AM
VSsc400
VSsc400's Avatar
Default Gas tank pressure poll
Please take this poll.
When you go to the gas station to fill up and when you open the gas cap does it make that sound of pressure being released?
My car doesn't and I think it should.
Old 03-20-05, 06:38 AM
bob2200
bob2200's Avatar
Mine doesn't and never has.
Old 03-20-05, 07:51 AM
Lexmex
Super Moderator
Lexmex's Avatar
Mine does.
However, I must clarify this. When I run Pemex Premium gasoline in Mexico, I always hear this sound.
When I run U.S. gasoline, any variety, I never hear this sound.
Old 03-20-05, 08:14 AM
HarrierAWD
HarrierAWD's Avatar
I hear this sound no matter where I fill up. Either at sea level or 6,000 feet. It sounds like it's sucking air in.
Old 03-20-05, 12:49 PM
parula
parula's Avatar
No, but do often on the Honda fwiw, more in the summer as I recall. Honda has the original gas cap too which the State inspections actually check for a good seal every 2 years. No gas smell in the garage with the 2 cars.
Some info on Reid Vapor Pressure http://www.in.gov/idem/air/standard/control/m05.pdf
Old 03-20-05, 03:48 PM
Rockville
Rockville's Avatar
Default Gas tank air woosh more common in Summer heat
The RX series have plastic gas tanks and are not known for much woosh when you open other than the hottest days of Summer. The new RX400h has a sealed metal tank and it requires an equalization of pressure step for the fuel door to open. This might add 15 seconds to filling up but reduces any emissions.
Old 03-20-05, 06:22 PM
NeverSatisfied
NeverSatisfied's Avatar
This happened on my Prelude & IS. The 2 former cars also used 91 octane. Doesn't happen on my RX using 89 octane.
Old 03-21-05, 04:34 PM
parula
parula's Avatar
Rockville, if a plastic gas tank, is the lack of pressure due then to the plasticity of the tank expanding with pressure somehow minimizing the pressure to the cap?
Old 03-23-05, 07:06 AM
Lexmex
Super Moderator
Lexmex's Avatar
A lot of guys at my local track pour in the little NOS bottles you find at Walmart. They have a fuel injector cleaner, an off-road formula and a racing formula.
I can tell you when I have tried these products, the pressure is way more pronounced than if I just run premium gas alone.
I can also add it really did not add up to much in the 1/4 mile. However, several buddies radically improved their times after dumping in two bottles.
Next time I use Techron for my injectors, I will let you know if there is more pressure.
Old 03-23-05, 08:46 AM
HarrierAWD
HarrierAWD's Avatar
I hope they didn't pour NOS into the gas tank (it's impossible and it's not how NOS is used.) They'll laugh the whole way to the 1/4 mile.
Want better time? One word buddy: SUPERCHARGER Excellent for high-altitude use.
Techron is too mild. If the gas in Mexico is really that bad, pick up some ChemTool B-12 when you're in the States. Techron = Bud Light. ChemTool = Jack Daniels.
Old 03-24-05, 07:45 PM
Lexmex
Super Moderator
Lexmex's Avatar
I should clarify. The stuff is not NOS, but it is made by the same company. They are Octane Boosters.
I used the Techron because the car runs a little bit better, not necessarily to clean the injectors any more. For that, I use Restore fuel injector cleaner.
The TRD supercharger will not work in the VVTI engine properly, not reliable. Even if it did, the gains, I believe 40-50 hp, does not justify it. TTE made a compressor-type supercharger that got about 49 and does work with the RX300. However, I want more power.
What I plan to do is do a Turbo mod when I get back to the states. Already, my mods are giving me good power at my altitude.
Old 08-14-05, 10:32 PM
koolaidman
koolaidman's Avatar
dont worrie about it. some times u get it in the middle of a drive cycle. but most of the time u are not in the middle of a drive cycle and u wont hear the noise. its perfecitly fine
Old 08-15-05, 01:26 PM
Lexmex
Super Moderator
Lexmex's Avatar
I don't even bother worrying about it any more.
I do have one problem with the gas tank. When I am just about to hit the low fuel warning or even when I hit it...then fill up...gas tank does not show full.
End up having to pull one of the batter cables to get it reset.
There must be some crud at the bottom of my tank.
Old 09-10-05, 02:44 PM
koolaidman
koolaidman's Avatar
it happens not all the time but it happens. usually when the char can. is beeing used to remove o2 in the system. there is nothing to worry about if u dont hear it
Bankswood
Performance & Maintenance
15
05-22-16 10:49 PM
biodev
06-08-10 07:22 PM
KingNasGS4
19
03-12-09 07:51 AM
neurocity
12
10-02-06 06:12 AM
Ashbypa
06-01-03 07:18 PM
Quick Reply: Gas tank pressure poll
