Vehicle Speed Sensor (VSS) for Navigation
I'm installing navigtion system into my RX300 which has to be connected to the VSS (vehicle speed sensor)
People are saying it the violet/white wire. Where is it located on a 1999 rx-300? Is it connected to the main ECU or the cruise control?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
By the way where are people tapping for the the reverse light (Tail end of the car)? or at the shifter? and the illumination
Please provide wire color and location if known
Constant 12V+ White White/Blue Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Black/Yellow Ignition Switch Harness (heater)
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake n/a 12 way Connector in Driver's Kick Panel Pin 9
Cold Side of Brake Green/White (-) 12 way Connector in Driver's Kick Panel Pin 9
Tach Orange Right of Fuse Panel in 20 Pin Connector
VSS Lead Purple/White Pin 12 at CCM in Driver's Kick Panel
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness (heater)
Ignition 2 Black/White Ignition Switch Harness
Accessory Pink Ignition Switch Harness
Brake Switch Green/White (-) 12 way Connector in Driver's Kick Panel Pin 9
Trunk Pin White/Red (-) Driver's Kick 20 Pin Connector low in Panel
Parking Lights Green (+) Back of Fuse Panel 11 Pin Connector
Head Lamp Red/Blue (-) Steering Column
Hood Pin Red/Blue (-) Engine under Relay Box Driver's Side Gray Connector
Factory Disarm w/Locks
Door Trigger Red/White (-) Left of Steering Black 13 Pin Connector Position 2
Door Lock Pink (-) Harness between Module and Door Actuator
Door Unlock Pink/Blue (-) (and Gray) in Passenger's Door see notes
Horn Wire White/Red (-) Steering Column
Windows Up LF=Red, RF=Red, LR=Red, RR=Red
Windows Down LF=Green, RF=Green, LR=Green, RR=Green
jucee187
08-19-04 09:21 AM
APU6speed
07-15-02 09:43 AM
