RX300 Brake pad direction?
After 72K mi I needed to install pads... I purchased factory pads/rotors from Irontoad. Just put my front rotors and pads on. I opened the box of pads and noticed the pad face has a 45 deg champher ground on right hand side and a large concave portion ground down on the left hand side. I installed the large concave champher towards the back so the rotor rotates into this area. Did I put this on right?
It seems to be working fine...
Thanks
Thanks
It has been a while since I replaced mine, but don't they have a wear indicator lug, that assures only one way mount.
But then no one should argue with success.
Salim
Salim
The front shoes didnt come with the wear indicator lugs installed. Its just a clip on part that can be mounted on either side. I un cliped and used the ones from the old brakes. The rear brakes do have large indicator clips rivited on. Its all working, not a squeek out of them...
