Misfire cylinder 6
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I have a 99 RX300 with 89,000 miles. The check engine light came on and the motor started running rough. The code reader says there is a misfire in cylinder 6. I suspect that an injector or maybe the coil pack or plug may be bad. My question is which cylinder is #6? I can't find any engine diagrams that shows cylinder numbers. Thanks for any help.
I was able to get the firing order. It may be handy if you get a code that specifies a certain cylinder.
I switched the coil and found one was bad. Luckily #6 was easy to get to.
From Alldata
Firingf order 1-2-3-4-5-6
___________________
1 3 5
2 4 6
___________________
Front of motor
From Alldata
___________________
1 3 5
2 4 6
___________________
Front of motor
Out of Warranty
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Buttered side down effect, I guess . . .
