Rubbing noise from front wheels while turning
I've got the same problem with left turns. recently had the Rt. Rear bearing replaced, so it's probably the front one, or I need a brake job.
It sounds 'metally', like the wheel is rubbing on the inside of the wheel well.
I have a Toyota Harrier 99th year. Yesterday, noted that the on pits or on bad roads back to running gear creak appears. similar to the rubber that it is. What would it be help please
Super Moderator
If it is rubber creaking, it might be these lower rubber supports that go at the bottom of the spring.
Super Moderator
I now use hose in place of the rubber.
For each spring, you need 55 cm length and 2 cm width plastic hosing as shown.
See this full link on shocks, https://www.clublexus.com/forums/rx-...yb-gr-2-a.html
Tnx Lexmex.
Also sometimes from rear shock absorber or something appears rap.But shock absorber is working good.
What happens if i will use both of them, i mean hose also insulator is it possible?
Super Moderator
Super Moderator
If that's not the case, I'd inspect the pieces at the top of the shock (after you have removed it to see if the pieces below are in good condition. These are pieces located on top of the shock, the strut mount (top photo) and bumper (in the bottom photo, the orange colored rubber piece on the bottom of the shock on the silvery pole area). The strut mount is expensive (over 100 USD for just one, while the bumper is 10 USD), http://www.trademotion.com/partlocat...layCatalogid=0
You can try lubricating them. I don't know if you have something there like WD40 lubricant, but if you can find a lubricant spray, you can spray those pieces and that can help diminish some of the noise.
Hello to all, this is my first posting. I have a '99 RX 'Sport' (did a previous Owner makeup a badge and stick it on?), with 110K. I am the third Owner, I think. When I accelerate from a stop, I sometimes get a slight shudder that I can feel through the seat. Does this lead one to think the CV Joint is going bad? Otherwise I love this car; it is my first foray into the luxury club.
in '99, but if there was, I'm sure someone will chime in about it. Good Luck and Welcome to CL!
