Quietest Tire For RX300?
#31
Originally Posted by mikey00
Not true. 700 is the treadwear rating of the highly rated Cross Terrains. One of the best for ride comfort, noise and bad weather handling. Check it out at tirerack. Don't go by consumer reports. They tested the OEM version of the Cross Terrains which is only around 400. I have almost 60K on my set of cross terrains and will be getting a second set soon.
CR buys tires at retail like consumers do, no OEM for CR. They put all tires through the same controlled scientific testing. I can't post the tire test results here (to protect ClubLexus from copyright infringement.) Go to your local library and check the November 2004 issue. Then decide for yourself.
I check CR before I buy just about anything.... from toaster to vaccum, including my RX300. I have to say that I've never been disappointed.
#32
Must jump in here on the CT tire. Have owned various autos for 50 years or so and the CT is by far the best running and quietest tire so far. Purchased mine after the CR report and can't imagine what tire they were using. Have 55000 miles on them so far with even wear and no rebalance.
Would not base any purchase soley on CR findings. Might use them for info but that it is all.
It appears from the specs that the 235 tire is somewhat different tire than the 225, looks like the 235 tire was made as an oem for Ford.
The CT was a VAST improvement over the Goodyears!!!
#33
Originally Posted by HarrierAWD
Apparently Michelin changed the compound for Cross Terrain. So the new CT is not as same as your current set. The CT is the worst handling tire among 22 tested by CR. Ranked #18 out of 22. Don't let CT's high price fool you. According to CR, many tires beat CT hands down at half the price.
I check CR before I buy just about anything.... from toaster to vaccum, including my RX300. I have to say that I've never been disappointed.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
#34
I checked the Michelin CT website and its spec PDF file. There's no difference between 225/70R16 and 235/70R16 - other than the 235 is Ford OEM. So if the 235 sucks, so does the 225.
People are comparing Michelin CT with old worn out OEM Goodyear or Bridgestone - which wasn't stellar to begin with. Of course the CT is going to feel like a much better tire. My point is that there are even better tires out there at lower price, based on CR's scientific comparison test.
Of course, people are free to ignore testing results and simply go by their feeling. I choose to study the facts thoroughly. My GY Integrity will wear out before this coming Colorado winter. I need really good tires. After all, my own safety is on the line.
BTW, the 700 compound is new.... helps with the 65K-mile warranty, but won't do jack for ice. The Toyo M410 Open Country is a good example. It used to be very good on ice. After Toyo changed the compound, it is now rated poor. (See CR Nov. 2001 and Nov. 2004 issues)
#35
#36
The CR ratings need to be taken with a grain of salt. There is enough difference between different sizes of the same tire in general, so as to affect any performance or treadwear characteristics.
We bought Yokohama Avid Tourings (185/65 SR-14) for our 99 Ford Escort ZX2, and were very happy with them. But when I bought the same brand for my 95 Plymouth Grand Voyager (205/70 SR-15), they did not seem to wear as well. Unless CR rated the exact size that you need, you can't use their ratings as gospel.
Also remember that the treadwear ratings are put on by the manufacturer, and are not yet standardized across manufacturers. So for example, a Bridgestone with a 400 treadwear rating, may not last as long as a Goodyear with a 400 rating, or may last longer.
We are all just looking for recommendations as to what is a quiet tire. There is no need to get into heated debate about this.
The OEM Bridgestone Duelers are quiet, but I haven't found them to be the best wearing tire. I have new ones on the 2002 we just bought, so I am stuck with them for awhile.
So I am thinking maybe Michelin CTs next, or maybe Yokohama Geolandars. I'd be interested in hearing more about what other tires people have found to be quiet, or not quiet on their RX300, and with long tread life. But I am not interested in a debate about who makes the best tire! Go over to a tire forum for that.
#37
Originally Posted by mmahamm
...Also remember that the treadwear ratings are put on by the manufacturer, and are not yet standardized across manufacturers. So for example, a Bridgestone with a 400 treadwear rating, may not last as long as a Goodyear with a 400 rating, or may last longer...
Actually the treadwear ratings are directly comparable across manufacturers. They are not numbers assigned by the manufacturer.
The Uniform Tire Quality Grading rating is a quality rating system developed by the American Department of Transportation. It is designed to show the relative performance of passenger tires (but does not apply to winter tires for now).
The treadwear rating is based on a wear test performed on a 400 mile government test course covering specified sections of public roads in Texas. A group of not more than 4 test vehicles travel the course in a convoy so that all tires experience the same conditions. Tread groove depths of the tires being tested are measured after each 800 miles. The same procedure is followed for a set of "control" or "course monitoring tires" Upon the completion of the 7200 mile test, the rating results of both tires are compared, and the tires being tested are assigned a treadwear rating according to government standards. This number can be used to compare between tires. In the case where one tire is rated 600 and another 300 the one rated 600 should last twice as long as the tire rated 300. The relative performance of tires depends upon the actual conditions of their use and may be significantly different from the norm due to differences in road characteristics and climate.
#38
If you read the Michelin specs the first thing you should notice is that an asterik will take you to a footnote indicarting that the 235 size is a special OEM tire. Next, notice that the 225 has a wear rating of 700 , while the 235 is only around 400. That big of a difference should tell you something. Next, notice that the tread depths are different. I have had 225 CTs for over 2 years and they are as good as any on ice. You may want to do a search here and see what others are saying. The only neagtive press is the Consumer Reports article, and again they tested the OEM version.
#39
Realising this is a bit offtopic (noise) but the treadwear on the Michelins (either) is vastly better than either OE tire.
all 225/70/16
Sku
064378........ DUELER H/T 687 BW....300
402469477. INGEGRITY .....................460
75883...........CROSSTERRAIN SUV ..700
62260...........LTX M&S ..........................500
Actualy the Integrity has a high treadwear; But that cant take into account how ****-poorly the edges wear !
all 225/70/16
Sku
#40
Even though the tire may be the same brand, they are not necessarily the same tire sold from dealer to dealer. The tire you purchase at a tire retailer is not the same tire sold at Cosco, Walmart, Sears, Penny's or K-Mart... they're all the same brand, just not the same tire. There are slight differences in tread design, tire belt thickness, core sizes, compounds and most important - Price..or Quality. How does the tire balance and ride after 10K miles?
Check the tire websites and you'll find the "tell tale" are the federally mandated tread wear numbers are different from tire to tire. The sales people down play this, but how else can there be a large difference in price. It comes down to the basics, you get what you pay for and tire makers have adapted. This is the age of international supply. Do some research and you discover the small differences in the tire specs. The old term Blemished comes to mind but tires aren't blemished anymore, they're just sold to another retailer at less cost. Large Box retailers are forcing manufactures to produce a tire that is price driven. This is the dirty little secret dealers don't want to discuss.
#41
Tammy, I'm not a tire expert by any means. But, it seems to me that a Michelin MXV4 or Goodyear Eagle RSA purchased at Discount Tire would be the same tire as a Michelin MXV4 or Goodyear Eagle RSA purchased at Sam's Club or Costco. Are you saying that's not the case??
#42
#43
My "cheap" Cross Terrains from big box retailer Costco have a lot of the specs stamped right on them. Some of the more important ones like tread wear rating match the Michelin specs exactly and also match the specs of the Cross Terrains from the high price tire stores. I seriously doubt there is any difference.
Go look at a tire you like, Michelin, Bridgestone, Goodyear, etc, and physically go look at this tire in the same size and load rating at any number of stores and guess what? The UTOG numbers will be identical regardless of where you find it.
#44
Generally speaking, tires with higher tire wear index tend to be quieter on the highway since the compound isn't as "sticky." However, tire wear index alone is not the reason to select a tire.
I personally wouldn't go for anything over 500 due to the ice & snow I get around here. So 700 would be suicidal. For those who live in the "Sunbelt", don't care about handling, and want to save money, the CT seems to be a fine choice.
The Nov 2004 issue of CR has found a few very quiet tires. Go to your local library if you are interested.
#45
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
The Dueler H/L Alenza with UNI-T and UNI-T AQII is Bridgestone's light truck and SUV Highway All-Season tire that was developed for the drivers of premium, luxury sport utility vehicles. The Dueler H/L Alenza is designed to provide elegance with an edge, as well as year-round traction, even in light snow.
Results from our online tire survey: 77 surveys submitted 157,687 miles reported
Dry Traction 8.8
Wet Traction 8.7
Hydro Resistance 8.5
Snow Traction 8.4
Cornering Stability 8.5
Steering Response 8.5
Ride Comfort 8.3
Noise Comfort 8.5
Tread Wear 8.6
Treadware rating 600-700
Key: Superior (8.6-10) Excellent (6.6-8.5) Good (4.6-6.5) Fair (2.6-4.5) Unacceptable (0-2.5)
Would You Buy This Tire Again? Most said: Probably (Average of 8.3 out of 10)
How Did This Tire Rank In Its Category? 2 out of 62 tires (Score of 8.5 vs best tire in category score of 8.6)
Dry Traction 8.8
Wet Traction 8.7
Snow Traction 8.4
Ride Comfort 8.3
Noise Comfort 8.5
Tread Wear 8.6
Guess this just points out that a high treadware rating doesn't necessarily mean poor snow traction. FWIW, based on the survey results, this tire outperformed the Goodyear and the Michelin in every category,
Oh and road noise can be more impacted by tread pattern design than hardness or softness of the compound or the treadware rating.
