SRS Indicator
I have an 1999 RX300 with 62k miles and the SRS indicator stays on after sitting all night, after driving it for awhile it goes out and then the next time during the day the car is started it comes on and goes out in the normal fashion. Any ideas for easy fix besides disconnecting the battery?
Hello,
I think need (for the Clarification)
-Read trouble code(s) ( for example, by using pins Tc and E1on DLC No.1
( http://alflash.narod.ru/_derived/DTC...xt_ChEngT2.gif )
-Clean (reset) memory SRS ECU ( for example, at http://alflash.narod.ru/Temp/ab0001New.gif )
-again check codes
OR
read DTC and do reset by using Scan Tools (on Service)
HTH,
-again check codes
OR
HTH,
Lexx2007
03-04-13 11:17 AM
GamblerZ
Performance & Maintenance
05-18-12 07:45 AM
i3urton
RX - 1st Gen (1999-2003)
15
01-04-08 11:01 AM
