Rotora BBK for RX300
Finally I got my BBK installed, beside looking nice, the brake performance drastically improves over my old front setup of Brembo blank OEM size + Akebono.
There is plenty of clearance with forged aluminum 18" SSR Competition, tire is 235/60/18 Pirelli Scorpion Zero. I have 25mm wheel adpators on all four corners to make wider stance, since offset on SSR is +45, wheels need these light weight H&R aluminum spacers to clear rear struts and able to make complete turns w/o rubbing up front.
![](http://img254.imageshack.us/img254/9523/rotorabbkcj8.jpg)
4 piston caliper in hot red, Gorilla cold forged steel lug nuts, one that is bigger is Gorilla wheel lock.
![](http://img387.imageshack.us/img387/3637/caliperbbkoo6.jpg)
13" rotor, two piece, cross drilled and slotted, black e-coating on non-frictional surface
![](http://img488.imageshack.us/img488/5262/13rotorbbkao9.jpg)
Thanks, the front BBK makes my rear Rotora OEM sized slotted rotor + Akebono very ordinary looking. The rusted inner ring is not Rotora's design, in fact, you will get that as long as OEM caliper and pad are used.
![](http://img370.imageshack.us/img370/3104/rearslottedrw3.jpg)
Super Moderator
Seeing that you are running the 235-60-18. I could have sworn that when I took a close up look at one Harrier at a stop light (did take a picture but it just didn't go through on my phone) it said 235-60-16, unlike the 225-70-16 stock tires on our RX300s.
Gorgeous RX! I don't care what other's say your RX looks great and the BBK works for me!
JeffTsai
03-04-14 09:50 PM
