Washer Fluid Reservoir
Is there a separate reservoir for my rear windshield and wiper blade assembly? If not, is there anyone that has problems with their rear cleaning system on their 2001 RX?
I have to hold the washer lever down for about 3-4 seconds before I actually see fluid coming out of the rear cleaning system.
As the fluid is drawn from the only reservour which is at the front, you can imagine how much of it has to be pumped through the line along the length of the car before you see it spraying onto rear window.
Super Moderator
I had a problem with one of the front ones being clogged.
The other day the light started to come on when I went to clear the front and rear windows, but the rear is just delayed a little until the water gets down there even with a low reservoir.
slowtan
RX - 1st Gen (1999-2003)
11-12-03 02:30 PM
