where is an easy to access ignition switched power?
I have a car pc I am working on and the power supply needs 12V constant, 12V switched and Ground. Where in the front of the car is the easiest to get these wires and what color are they? Thanks a million in advance
The cigarette lighter is a switched 12v, there are only two wires, one red and one white witha black stripe.
I would just put a multi meter onto red wires with your meter black wire tourched to the steel chassis until you find 12v with the ignition off. Or you can run a wire to the fuse panel behind the driver side fuse box
1UZFE4ME
SC- 1st Gen (1992-2000)
03-19-13 06:59 PM
