buzzing sound????
sup guys... happy new years .... well lately i been getting a loud buzzing sound coming from my dashboard area.. when the heater is on or after i turn it off.. its just a loud buzzing sound that will come and go when ever it feel like after i use the heater.. does anyone know why there a loud buzzin sound? i took it to the dealer they dont even know ...
Please search "air servo".
The buzzing sound which comes for a while and quits is typical or the servo motor trying to overcome the dampers and then quit.
There are more than one servo and typically the mode servo dies first as it is used more. You can most likely reproduce it by changing the "mode" setting [feet level, face level etc]
Salim
Salim
Sorry!
Changing mode should sensatize the"mode servo" ... it is not a cure.
Adjusting the temperature from one extreme to the other should sensatize the "mix servo".
The cure is to replace the right servo. Servicing the servo may help it limp along [Read the instructions carefully as you should reassemble it the arm at the same angle when you start].
Salim
Salim
donatasiv
12-29-17 11:12 AM
