i need help with my radio
Old 01-26-06, 03:31 PM
falvar
falvar's Avatar
Default i need help with my radio
I need help…. my 1999 rx300 radio is not working and I am trying to get to the antenna but don’t now how. If I drive close to a radio station the radio works. And I look in back of the radio and the antenna is connected so I am assuming it is the antenna or the connection in the back. Please can anybody help me.
Old 01-26-06, 03:39 PM
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
Do you see the antenna mast extened out when you are in radio mode?
If so, the next step ought to be removing panels to get to the back of the radio and see if the connection there is good.
Once you eliminate the antenna + wire, there is a possibility that there is something wrong with the head-unit.
Other information, like what event caused the radio not to work would be helpful.
Salim
Old 01-26-06, 03:52 PM
falvar
falvar's Avatar
The radio was working and it stop it sounds like the antenna is not hook up I get the engine noise. I check the radio and the antenna is connected, I think I have to get to the antenna in the back but I don’t know how. By the way the antenna doses go all the way up
Thank you
Old 01-26-06, 10:55 PM
salimshah
salimshah's Avatar
If you still have access to the head unit, test out by plugging an external antenna {radio shack or other]. By the symptoms you describe the problem seems to be in the headunit. The antenna wire is robust and does not go bad by itself.
It has been few months but some one described how they replaced the antenna motor. May be some one can post motor removal process from the service manual. [although you antenna motor is good] you may have a break in the antenna wire [unlikely though]
Salim
Old 01-27-06, 08:07 AM
falvar
falvar's Avatar
thank you i will try a antenna from radio shack
Old 01-27-06, 08:11 AM
salimshah
salimshah's Avatar
Oooo, I almost forgot to mention that at times the presets for radio drift. ie if you have set "2" to FM104.5 one fine day it will try to tune 103.x. Solution is to reprogram the pre-set.
Before you do more exploration, I would suggest ry the manual tune.
Can some one confirm that the RX has two antennas [whip/mast] + "Y" (yagi) built in the rear glass.
If so, connecitons to both antennas need to be bad to get very weak signal.
Salim
Old 01-27-06, 02:59 PM
falvar
falvar's Avatar
i went out a bought and antenna and connecet to the back of the radio, nothing but noise i can;t pick up any stations
Old 01-27-06, 05:58 PM
salimshah
salimshah's Avatar
If you have already tried manual tuning, its time for a new head unit or have the current one repaired.
Salim
Old 01-27-06, 09:16 PM
sourLX470
sourLX470's Avatar
I would check the power going into the head unit. Check the fuse. Check the grounding. It sounds like you have a power flow issue. I had a head unit make more noise when the engine was on because of a bad power wire. It's not your antenna because you get the same problem when you hook up the external antenna.
This is just my opinion and I am just giving suggestions as to what to look at.
Old 01-29-06, 01:44 PM
falvar
falvar's Avatar
i can play cd and the sound is great.....but no radio the noise sounds like the antenna is not hook up. i guess i have to change the whole thing....or maybe someone has a better idea
thank you for all your help
Old 01-29-06, 05:43 PM
salimshah
salimshah's Avatar
I keep bringing it up, but did you try manual tuning of radio station.
Salim
Old 01-31-06, 03:59 AM
falvar
falvar's Avatar
yes i did..............i even try scaning everthing and it won't pick up a station.
kmeehan
05-23-19 08:12 AM
boxcarfan
GS - 1st Gen (1993-1997)
08-19-10 09:51 AM
lamar411
05-30-10 08:31 AM
rx300new
12-27-08 07:00 AM
kevin333k
02-25-04 07:42 PM
Quick Reply: i need help with my radio
