1999 RX300 need door cladding
Does anyone know where I can find the door cladding for a 1999 RX300? These are the plastic bottom panels . I need right rear passenger door cladding and the small portion that abuts the right rear door and right rear wheel well. I found at dealer for $224. plus for both, before tax.
I would appreciate any help. Thank you.
I forgot to add that the electric driver's seat no longer moves up and down. I can hear the motor try to move it, but it can't. Anyone have any thoughts on that as well.
Again, thank you for help.
Have you checked for an obstruction down in the rails the seat rides in. It dosen't take much of a happy meal toy to jam it. You may want to consider removing the seat bolts and inspecting the underside.
Check with the sponsors too.
The good thing is that they come pre-painted [can be slightly bad as they may not be an exact match due to fading and difference in batch of paint.
Tip: As long as there is a gap between two painted panels, your eye can be easily deceived, and it is hard to tell there is a difference in shades.
Salim
Salim
