help replacing the rear speakers
Finally one of the rear speakers died.
I need to change them, and I have a couple of questions. Does anybody knows the item number for the OEM ones?
If anybody has changed the OEM ones without breaking anything on the door, which speakers do you recommend?
It is imperative to keep the external aspect as it is.
Thanks for the help.
i replaced all my door speakers with infinitys. they sound way better. i'm using an aftermarket alpine amp to run it all. i don't recall the size of the rear door speakers but all you hafta do is match the size and they'll fit behind the stock grills. nobody will be the wiser...until they listen to it
rebushnell
02-14-12 10:56 AM
binelus
05-12-04 04:14 PM
