Bad Window Bad
Super Moderator
Here is my problem:
The front driver window is not held in place. I found the window at a diagonal recently. If it had fallen perfectly straight it would have broken. A local shop says its a bad regulator.
The motor works fine. I can hear it going up and down when I push the window switch. When it gets to the top it knocks into the window a bit. It seems like the window is just not attached to the scissors bracket/motor anymore. What do you guys think? Right now there is tape (ghetto) holding the window in place.
It's a 2001 RX300 SS.
My stealership said it was the switch AND regulator (motor). Thanks LexMex for the info and pictures and everything. I'm guessing it is a safety feature, so that little fingers, like kids, don't get smashed. To me, as long as the motor is running, it's not the motor. And most likely replacing it won't fix the problem. I did the deep clean. Here are my symptoms. Passenger side rolls down with no problem. rolling up would stick and stop. sometimes it would stick and roll back down. Sometimes, just stick in the down position.
It 's too smart and probably thought someones head was in there.
I took it apart, used deep purple from wal-mart and cleaned everything real good. then white spray greased the rails and joints, just like the Lexmex directions. I didn't clean the actuator, cause I didn't see any details on what to clean and how. I also cleaned and greased the window glass rails. and I used electrical spray and wd40 on the switch. everything is working better than new. THANKS!!!
I read the posts and the removal info was great, but i cannot seem to keep the window in the channel that is attached to the motor. it is held by a rubber gasket in a metal channel. is there anything i can use to get the rubber to adhere to the glass more securely? thanks
Super Moderator
I'm not exactly sure what you are referring to. Is there a particular part of one the photos that might help me figure it out?
In the removal of the window from the lifting arm in your picture there are 2 10mm bolts that hold the window to the rail. In my Lexus, the window sits in a rubber lined channel without positive attachment (gravity only.) I put a piece of packing tape across the bottom of the window, to increase the thickness, which i consider a temporary fix. I am looking for a permanent solution. Are there any "tricks" to get the rubber to hold on to the glass? Is there adhesive that is designed for glass to rubber? Do I just need a new rubber channel?
thanks for the help.
Super Moderator
Thus, if putting extra tape to keep it fit in the channel doesn't work, then it's something electrical there.
I've had hell in dealing with my own driver's side window and all the current greasing has only helped a little. A recent replacement of my battery did help somewhat get a charge there, but I do know that the motor itself is on the way out.
Thanks for all the advice, the pictures were very helpful, it's really only on the going down that the problem occurred so I'm inclined to believe it's the channel not the motor because up is not the problem. I'll 'stick' with the tape and see if that will be my final solution.
Thanks Again
Thanks Again
