Photo DIY: RX300 AWD Transmission Fluid, Pan, Filter Change
#241
70k miles on 2000 RX300, former owner had Lexus dealer replace 4 quarts on two different occasions. I opted to do a 12-quart change with Toyota transmission fluid. Transmission was drained and that measured 3.5 quarts and another 1/2 quart measured from transfer case--the fluid was dark but not burnt and probably was do for a change. Put in new fluid and drove car for 6-8 miles. Repeated process three times for a total of 12 quarts. Fluid looks really nice. Very simple procedure. From this point forward, in keeping with those who have placed substantial mileage on their transmissions without repairs, I will do the 4-quart drain at 15K mile intervals. At least in this manner, if I have a trans failure I can probably eliminate any concern that it occurred because of a lack of trans fluid changes.
#242
In case this helps anyone, my car's transmission was starting to slip a bit. The other day, I went up a steep incline and it just revved really high without engaging.
I purchased the Wix 58618 filter kit (it came with filter, o-ring, and transmission pan gasket), 6 quarts of Royal Purple ATF, and 1 bottle of Lucas Transmission Fix.
I got about 4 quarts by draining, dropping pan, and replacing filter. I did a drain and fill with filter change about 3 years ago and haven't driven the car much since then. The pan had gunk on the bottom and fluid didn't look horrible but was a bit dark. Magnets seemed like they had a normal amount of shaving for 3-4 years. I couldn't get the transfer case plug out as I stripped it a bit. I put everything back in (put all the screws through the pan and gasket before putting back on) and pour 3 quarts of Royal Purple through dipstick hole. I then remove the hose from the cooler and pumped out about 3 quarts. I stopped when the color of the fluid changed and it started to sputter.
I put in another 3 quarts of Royal Purple plus the Lucas Fix (which has the consistency of honey). After test driving, the results were immediately noticeable. Shift were smoother, acceleration more precise, etc.
I'm not sure if it's because I change the filter, replace 6 quarts of ATF, or because of the Lucas but it seems to be working pretty well right now. I'll update in a few months.
#243
I am running into somewhat similar problem. Did the complete transmission oil as well as pan change 3-4 of years ago and i only drive about 8K per year. And i did plain transmission oil change sometime last year. Recently starting seeing some hesitation in transmission especially when reversing from my garage and occasionally some hesitation in inclines too.
Am going to do another pan drop and change in next few days.
Does folks on this forum encourages use of the Lucas Transmission fix?
Also i already bought the Toyota T4 ATF. I am hoping that is okay and i don't need to look for Royal Purple.
Mine is a 2WD and had the understanding that most of the transmission problems come on AWD. Keeping my fingers crossed now.
#244
Guess I wasn't paying enough attention to instructions because when I poured the old fluid out of catch pan I found the O-ring in the bottom. The car runs fine after doing the work but is it OK if it's not in there?
#245
I have two O-rings but autozone says the new filter does not come with one and that my car takes only one. How is that possible?
#246
What a day!
Dropped pan, replaced filter, had hard time putting back the pan, all the screws had a hard time to catch the threads.
When i bolted then in with an impact driver, they barely went in. One of the screws snapped in half.
Had a leak from the drain bolt, had a leak from the pan's gasket, what a mess!
I think whoever did the job last, ruined all the threads. Had hard time to even get them out.
Rushed to a toyota dealership near by, it'll cost me $650 for a new pan (it was dented already) and rework the whole thing.
I'm not going to do that again!
in the future, can I just drain the pan and transfer case? then refill. Would that be sufficient for a while? meaning, 30k+?
Also, the two hoses by the a/c compressor shown in step 9, my car doesn't have any of them, I have a 2002 FWD.
#247
What a day!
650 for a pan sounds ridiculously high, you should be able to find a used one for 100. There is one on ebay, but it is for a 4wd.
In the future, I would just drain the oil. Tranny Oil should be good for 50k miles or so, but that's my opinion. Then change the filter again at 100k miles.
#248
What a day!
#249
Wow, that is a rough day. Sounds like the threads were jacked up. Next time, I would consider going to buy a tap a die kit to help "reshape" the threads to better condition before using the impact driver. Only 30 bucks for a cheap kit at Advance Auto, or you can borrow one from there for free. Pretty easy to run the tool up in there to help reshape the threads a little.
you mean this kit?
http://shop.advanceautoparts.com/p/t...rm=tap+die+kit
How would this help in my situation where all the screws and threads in the tranny were messed up?
#250
You want to use a rethreader, similar to a tap and die set, but made to repair rather than cut threads. This one has bailed me out several times. Great for cleaning rust out of threads too.
http://www.sears.com/craftsman-40-pc...1&blockType=G1
#251
I spoke today (January 2015) with Lexus of Windsor, Ontario, Canada. The parts department advised that while 5W30 is in the original spec sheet for use with the RX300, a Lexus publication shows that 5W20 synthetic or 0W20 synthetic are also approved for the RX300. Apparently 5W20 is the most commonly utilized in their service department.
The foregoing Lexus recommendation is consistent with a very educational article about motor oils, which dispels many myths that seem to be repeated often in "oil threads." The article can be found here.
#252
Hi,
Quick question: This fully synthetic Valvoline ATF says it is compatible with T-IV fluid. It is easily available where I am. Is it as good or better than the original Toyota T-IV fluid and will it mix ok with the original stuff?
Thanks for the helpful photos and explanation
#254
I appreciate the link also.. very useful.
#255
