RX300 Weird Noise...
I drive a 1999 RX-300. With the vehicle running there is a sound much like a loud hard drive being accessed repeatedly is heard at the passengers left foot. It operates at an in irregular interval, but it doesn't stop until the ignition is turned off. I thought it was the CD changer, but that's not it- I took it out, etc. I just noticed it a few days ago. Anyone happen to know off the top of their heads? I just had the 50k service done on Sat.
I usually hear that sound near my central console near the radio and it comes out of the air vents. I sometimes hear it and sometimes I do not and know it is related to the AC condenser, but until that thing goes on the fritz permanently, I do not plan on messing with it.
Not sure what might have caused that at the dealer during the 50K.
Mine has the same sound - I'm reasonablly sure that is has to do with the a/c. I suspect it's a blend door when the a/c is running. It DOES NOT do it when the heat is on. Prob. some type of electric/servo motor that is wanting to either close or open a valve, I'm guessing. Annoying as all getout, completely random when it does it (other than always when the a/c is on). I thought it was the CD changer as well, but it definitely is not.
Anyone dug into theres and figured it out yet?
If one day, while driving over to my uncle´s on the weekend, I hear that noise again...my uncle and I will open it up and find that culript. Pretty accurate description, it does sound like a little door opening and closing.
If it starts doing, immediately turn the climate control to 80° to kick the a/c off and the heat on. That way, you can confirm my theory that it is a/c related.
Been dreading tearing into it, but I'm guessing the glove box might be the easiest route. The old screwdrive to the ear trick might help pinpoint where it is coming from...
ok guys heres an update. this past weekned, i took my panels apart to try and look for the culprit. couldnt find anything. however, i had to replace my starter yesterday, and as soon as i did, the noise went away....
yea im not saying it went away completely, as i can still hear it very very faintly, almost to the point of where i have to actually look for the sound. but i was actually surprised that i didnt hear it right after i changed it... we'll see though
I have the same problem on my 99' RX300.
I just found a article. Maybe it can help to solve this problem.
https://www.clublexus.com/index.php/...1/ac002l99.pdf
You are exactly correct. I have read on the forums that it is the electric servo motor that is running. The sound comes from the passenger side towards the glove box compartment area. Unfortunately, this is normal and can be heard if the radio is off the the car is pretty quiet.
