I like the looks also, my RX is the same color. Were they pretty much plug and play. Did the LEDs effect the bulb sensors on the dash or did they put the proper resistance in the light assembly?
Each light assembly has its own current stabilizer for LEDs. It was pretty to install.
how were you able to match up the color so good? is there information somewhere on the rx that says the name of the wood? or did you just make print outs of their samples and compared it with your dash?
Sherwood Canada guaranteed that it will match the stock wood. Actually it matched ~98%, but usually only I can tell the difference. The clear coat on Sherwood is softer and you can see some difference in different lights. But like it - it is real wood.
Meeta very nice and clean all around. Where did you get the chrome "L" for the steering wheel, I 'm looking to do the same?
That "L" was quite complicated. First they sent me the wrong part, then they sent me the correct one but in order to install it I had to Dremel the back of the emblem so it will fit perfectly. PM me for the URL, if you need it.
wow looks really nice the lights,do you have the tail lamp sensor in the car on due to the led lights?also did u have to use a relay for them??the interior is looking sweet.
Yes, I have while bulb for turn signals. Police is okay this is (I explicitly asked about it once)
Btw, what you think about my interior and leather:
where did u get these led from,was there any problems ,does your taillamp sensor pop up?really interested please give some feed back on this product.thanks
