1999 rx300 stereo install question
I am trying to install my JVC dvd player with a flip down monitor in my 1999 RX 300 but couldn't figure out the wires yet. does anyone know the wire colors (speakers, power, accessory, etc.) for this lexus model? my plan is to cut the speaker wires and run them from the JVC dvd player and tap into the power, ground, and accessory wires. thanks.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white/blue |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| SECOND IGNITION|black |+ |ignition harness |
| ACCESSORY|pink |+ |ignition harness |
| POWER LOCK|see direct fax | | |
| POWER UNLOCK|document # 1070 | | |
| PARKING LIGHTS +|green | |drivers kick panel *1 |
| PARKING LIGHTS -|green/red | |steering column |
| HEADLIGHTS|red/blue |- |steering column |
| DOOR TRIGGER|red/white |- |steering column *2 |
| DOME SUPERVISION|same as doors | | |
| TRUNK/HATCH PIN|white/red |- |drivers kick *3 |
| HOOD PIN|red/blue |- |*4 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|blue/silver dots *7 |- |steering column |
| TACHOMETER|orange | |right of the fuse box *5 |
| SPEED SENSE|violet/white | |*6 |
| BRAKE WIRE|green/white |+ |at switch |
| HORN TRIGGER|white/red |- |steering column |
| WIPERS|blue/blk - blue/red |+ |steering column |
| LF WINDOW UP/DN|red - green |A |in door at motor |
| RF WINDOW UP/DN|red - green |A |in door at motor |
| LR WINDOW UP/DN|red - green |A |in door at motor |
| RR WINDOW UP/DN|red - green |A |in door at motor |
| SUN RF OPN/CLOSE|not recommended | | |
| SUN ROOF LIMIT|not recommended | | |
| RADIO 12V|white/blue |+ |at radio |
| RADIO GROUND|brown |- |at radio |
| RADIO SWITCH|gray/red |+ |at radio |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA|black |+ |at radio |
| LF SPEAKER|pink - purple | |at speaker or amp *8 |
| RF SPEAKER|lt.green - blue | |at speaker or amp *8 |
| LR SPEAKER|black - yellow | |at speaker or amp *8 |
| RR SPEAKER|red - white | |at speaker or amp *8 |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U or 555F. *1 Located in a gray 15 pin plug. *2 This wire goes to the key cylinder illumination ring and reads the delay. *3 Located in a 20-pin plug, low in the kick panel. Test only with a digital multi-meter as some of the multiplex wires in the car are white/red. *4 In the engine compartment, under the relay box on the drivers side in a gray 17-pin plug, pin #1 *5 In a 10-pin plug. *6 Coming from the cluster to the cruise control computer, it is located just above the drivers main fuse/relay box. *7 This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors. *8 The amplifier is under the rear seat.
Nak system is based on cd changer (where the glove cmpt. for other cars is), head unit, display, amp (under/near rear seat), sub under passenger seat.
Signals from cd to head unit are differential (l+, l-, r+, r-) and non standard.
Tapping in, is not easy as plugs are not available [let me know if there is a source for male-female pair for the cd changer]. Your best bet would be to bypass the head unit and go to the Amp directly.
Lexus are not easy to add on to.
Salim
Salim
vondelinde
SC- 1st Gen (1992-2000)
01-07-09 07:50 AM
Boost_lee
05-03-08 11:10 PM
sk72
01-19-07 03:58 PM
CleanCL
03-08-06 01:37 PM
