Replacement bulb help
Ok so I looked at the light bulb FAQ and it didnt say. What bulb number are the small outer bulbs on the headlight? Also anybody know how to adjust the headlights as well as the fogs?
The bulbs are parking lights and use 168/194 size wedge bulbs. You can use either incandescent or LED's in them. I think you can only adjust the headlights if you have factory HIDs, but there should be two screws above the discharge bulb where you can turn and aim them.
Headlights (HID on no HID) both can be adjusted [normal and high beam].
I highly reccomend taking it to a garage, which has the right equipment, rather than aiming at a flat wall or adjusting the spot by the seat of the pants.
Why? it is safety related issue and once you have this bug in your mind that the spot is not right, you always feel that adjutment is needed.
Here in Texas, garages that issue State road worthy stickers, have the instrument.
Salim
Salim
HustleHard
SC- 1st Gen (1992-2000)
12-25-05 01:32 PM
