Won't Start after Timing Belt/Spark Plug Replacement
Thanks for all the advice everyone. I was about 10 degrees off on the rear camshaft. I took everything apart, turned the rear camshaft clockwise about 10 degrees and she's purring like a kitten.
Learned alot from this experience and I hope it helps others who undertake this project.
Alex
Alex
Super Moderator
However, if that CEL comes back, Autozone will let you check the OBDII code for free and if you get me the code we can go over it.
that means your timing marks are still off, you should turn the engine several revolutions after setting timiing to make sure the belt doesnt have some slack and the cams and crank come back to the proper position. or the cam sensor has a pinched wire or is damaged....
The timing on the Bank 1 (rear) is still off. You are lucky it was only 10 degrees off the first time. 1MZ-FE VVT-i is an interference engine, if it is 35+ degrees you will have to machine the that head. VVT-i sensors (cam position sensors) are 1-tooth sensitive.
Really? I read that this is a NON interference engine.
Super Moderator
Actually, I was able to reset the timing belt just removing the upper idler. But you need 3 wrenches and another person to hold cams in position.
Upper idler pulley I assume......
How did you keep the camshafts from turning???
The fact that I wasn't able to prevent the rear camshaft from turning is what got me into this mess in the first place.
Any advice you can throw my way is much appreciated.
I called Lexus and explained the situation. They told me $600-$700 for them to fix it. Obviously, I want to avoid that if I can.
I'll tear it apart again but I wan't to be pretty darn sure I'll be able to get it back to where it needs to be before I start.
Is there any other way to line up the camshafts to their correct positions other than lining up the marks on the camshaft gear and timing cover housing??
The reason I'm in this situation in the first place is because 1) I neglected to make my own marks on the gear and housing before I took off the belt and
2) Because I found it next to impossible to even see the mark on housing of the rear camshaft.
Biddles
Performance & Maintenance
62
11-21-17 06:15 PM
viperrgh2
25
09-29-14 05:41 PM
1killerls
46
08-15-11 12:25 PM
