Right Rear passenger window wont go down?
Can anyone walk me through taking off the door panel? The dealership said they could here the moter trying to work. They said I would need a new regulator. If so, could I being a novice, change this myself? I hoped I could take the door panel off and try to hit the regulator with a hammer to fix the problem. lol. Help. Justin.
Super Moderator
But I am having trouble taking off the door panel for the RX300. There was a screw behind the door handle but still thats the area still holding on to the door. Please help before I break something!! Justin.
Super Moderator
On the rear doors, there are 8 (4 screws and 4 clips) from what I can see. The one behind the door handle, you have to pop off the plastic piece to the left of the door lock (on the inside of the vehicle). I had to use a flathead screwdriver hen I removed the front door panel not too long ago.
However, as I recall with the that area behind the door handle, it is a PITA and there is a clip back there. You probably won't break anything, but you just have to get a screwdriver in there until you can move it out of position.
Justin;
Just keep in mind that a stuck closed window is better than a stuck open one.
What I mean is, if you get the window to budge, stop immidiately and raise it up. Make these incremental open and close to get the whole thing to work.
Salim
Salim
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Thanks for all the help!! I got the door panel off. I used a hammer to tap on the moter and the window now works perfectly. That saved me $300+. The dealership said I needed a new regulator and maybe a moter.
I'm sure they would have replaced both. Thanks again!!
It is eay to slam the dealer, but realistically you have not repaired the problem. [The motor is binding ... lack of operation/lube/stuck brushes etc]. It may work for you but then it might get stuck again. You would be very un-happy at the dealership who whould have charged you say $60/hr [rounded up to next half hour] and it fails in few days.
Since it was your time, I guess it is OK.
Salim
Salim
lol
SC400 / 300 Classifieds
07-12-13 08:21 AM
