Timing belt and Water pump
My RX 300, 2001 just hitting 90k and looking to change timing belt, water pump and some other stuff. Looking to water pump part number [I believe Toyota part will work as well]. Also with engine two other lights came up VSC and Track and not sure why they came up. Would appecite help.
Thanks.
Thanks.
The other 2 lights come on whenever the check engine light comes on... at least this is what I have read... I had a loose gas cap (97k) and my lights came on... tightened it and it went away. Use search and you can find the answers to a lot of questions. Let me know how much the service is for the timing and water pump... I think I am going to wait until 120k to do mine.
I believe you can use the same parts as I got for my 99ES and 00RX. This is what was listed on my invoices, you still should double check
timing belt 13568-09080
water pump 16100-29085
Super Moderator
A 1MZFE Highlander should be equal. With the Check engine lights you can pull the EFI fuse out for a few seconds or pull the negative battery cable out for a bit. Otherwise, head to an Autozone, have them pull the codes for you and we can go over them here in the forum.
I think they were charging me $900+. It was a while ago so I cant really be sure if that was the quote though. So can anybody tell me if I can go with aftermarket timing belt kits and be ok?
Lexus dealers around me want $900 too. I really wouldn't go with the aftermarket stuff because your not saving a substantial amount of money on the timing belt. The water pump is pricey, but unless leaking or broke, Lexus/Toyota dearlers tell me can be left in place to be changed every other timing belt change.
Super Moderator
As I remember this also cost me about $900 USD (timing belt and water pump) and that was 2 years ago (the last time I set foot in a Lexus dealer for service). My uncle and I could do it now for sure, but that won't be for a while.
