Outside temp sensor help...
OK...searched & found nuthin'... outside temp readin' always says 74 degrees... (well, it's not that warm...) this is coiming from the lady...so... where is it located & anyone else get somethin' like this???
If the temp is stuck at 74, the problem seems to be at the sensor and less likely with the wire or inidicator. Replace or have it replaced.
The sensor is located underneath the front bumper.
When working properly, I have seen the temp reading can be off +/- 3 degrees F.
Salim
Salim
It is a small black sensor just below the front bumper 12" off center toward the driver side. I would first look at it for damage from car wash, road debris, etc. If it looks ok heat it up a little with a blow dryer and see if temp changes. It looks very easy to replace if necessary.
Super Moderator
That's interesting. I'll have to keep that point in mind. I plan to put an intercooler down there, but I guess what I'll have to do is get one a little smaller width so this sensor can fit in front.
This whole time I was thinkin it was one of those bubbles on the dash by the bottom of the windshield. The location explains why on hot days the temperature is always a little high for me, but on cold days the reading is pretty accurate
disconnect sensor and see what you get as temp reading.
Salim
Salim
Glad it is working.
After the sensor, the connectors/wires would have been the culprit and then it would have been the ECU.
Salim
Salim
