Brake Pads DIY
#61
Super Moderator
Chachacha -- I may be stating the obvious, but make sure the parking brake is OFF before trying to remove those rear rotors. I always set the parking brake when I jack up the vehicle, but I also tried to knock off the rear rotors while the parking brake shoes were holding it in place Duh!! Much easier without the brake on....
#62
Super Moderator
Axxis Deluxe pads wholesale closeout sale at Rockauto.com for around $15 and $14 for front and rear pads.
http://www.rockauto.com/catalog/raframecatalog.php
BTW, on my brakes, I'm going to replace all the piston boots on Monday along with the dust boots for the slide pins. I ended up getting the parts at Advance Auto for a lot cheaper than Lexus. I don't plan to take out the pistons (that's a bit more complicated procedure) due to time constraints, but am going to clean the area of the pistons that is exposed. I probably will show the pictures in the lubrication thread that I mentioned and linked to at the beginning of this brake DIY.
The piston that I do have a bit out now (front, driver's side) had a little bit of accumulation on it, but no scratches. If I had seen scratches of any kind I would have considered replacing them (I do have the piston seals).
#63
I bought both brake pads for future replacement from Rock Auto. I noticed that my brake fluid reservoir got little below
level and brake sign came. I added little more fluid but didnot get lower since 2/3 weeks. May be leaks. I have to check.
#64
Super Moderator
I saw rock auto had a good deal on some brembo front rotors for like $12 bucks each yesterday. They do get some good deals and I regularly look at them, amazon, ebay and a few other places, it's all good competition.
#65
Hi,
My name is Riz and I am new here. Have been reading this forum for a while.
I need help with regards to pads and rotors. I have a 2000 Lexus RX 300, and need front and rear brake pads and front brake rotors replaced.
What do I need to buy ? Front/rear Pads, shim kit, hardware kit? what would be the best place to buy it? Lexus OEM parts of any third party? Local dealer (Indiana) have front pads for $80 Shim Kit for $46, and front Rotors for $107/each.
Thanks
Thanks
#66
Hi,
Thanks
Thanks
There are lots of places which sell OEM parts and I would suggest to get OEM parts from one of the Club Lexus sponsors. They facilitate this forum and every thing being equal, should deserve our business.
There are rubber boots and shims and based on their current condition may or may not need to be replaced.
You would also need brake grease (to reduce chatter). Do not buy this from Lexus as you can get it at substantially lower price and it can be generic.
CRC brake cleaner is not a must but can be handy incase you get oil/grease on rotors.
Salim
#68
I just did the rear pads + rotors.
I thought I had to adjust the parking shoes in order to take rotor out so I had to redo everything to make proper adjustment to the parking shoes so they don't scrap on the rotor.![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
The one thing I did notice is, the ACT325 that I got from JcWhitney looks different from the online and the photo on the first page.
The box is from Akebono and it says ACT325 on the side, but the pad I got fits the, but has significantly less pad surface(about 1/3 less than OEM pad) and also doesn't have the slot in the middle, but instead just one continuous surface with chamfer on each side.
Did they change model or I am just paranoid that it doesn't look like any of the photos online?
#69
I want to thank all the posters here for their contribution. I just replaced the front pads on my 2002 RX300
it took me about 2 hours (took my time). I purchased the front/rear ACT325 and ACT 930 pads from Auto Parts Place $115.24 (includes tax/handling/shipping). I will attemp to change the rear pads soon. Again thanks to all for your valuable input, it really helps a rookie like me.
Jojo
Jojo
#70
Thanks for the tutorial. Question. I inspected my 2000 Lexus 300 front rotors and I noticed what looked like criss cross marks. Are these made from the wear indicators? Is this a sign to replace the pads? I don't see any circular scoring of the rotor. Please advise
CharlieH
CharlieH
#71
hi all, my brake warning light on the dashboard has gone on and off a few times in the past week. i checked the fluid and it is around the min line, maybe a little below. from my research it sounds like the fluid only gets low when the pads wear out, so it sounds like i may have to get these pads replaced. i'm still a beginner when it comes to DIY, and i was wondering on a scale the level of difficulty of this repair and roughly how long it will take. i had some issues with another DIY, so i don't want to waste any time if the fix is too difficult or get myself into a situation where i make things worse. thanks!
#72
Jojo
Jojo
#73
Make sure you service (clean & lube) caliper slide pins and replace brake fluid if it is more than 2-3 years old. Don't just do a "pad slap". You will not be happy with the results.
#74
BECK/ARNLEY 0881311D AXXIS Deluxe brake pads are $24.79 at rockauto.
BREMBO 25552 Rear; 2WD; Solid; OE Replacement; Min Thick: 9mm [Wholesaler Closeout -- 30 Day Warranty] - $26.84
My RX300 has 167K miles on it. It is AWD. Can those rear brembo rotors(mentioned 2WD) be used for an AWD?
#75
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
