Spark Plugs DIY (if you have the patience)
#91
Thanks guys - still having some issues but I think they probably belong on a separate thread. Turns out you were right. Very good advice guys. I reset the current problems in my new thread.
#93
Using LexMex's process, will this work on a RX330 (2004)? Will I still be able to access the coil bolts
and then get to the plugs?
All thoughts appreciated!
#94
Super Moderator
I'd have to see a close up shot of the throttle body area and accelerator cable to refresh my memory though, but I didn't see anything difficult areas on the RX330.
#95
Will the following spark plug work fine on 2001 Lexus RX300 FWD. Also does the price look good?
Thought of confirming with you folks as it is not possible to return Ebay items!!
http://cgi.ebay.com/ebaymotors/6-DEN...#ht_4772wt_939
Thanks.
Trips.
Thanks.
Trips.
#96
Super Moderator
Thanks.
Trips.
Thanks.
Trips.
I am not sure on the price though, since I don't use those plugs.
#97
I have RX350AWD. Does anyone know if this procedure will work? I have engine light check and VSC on and wanted to troubleshoot coil 5. I have been told by one local guy that coils are hidden (1,3,5) and will require lots of work.
#98
Super Moderator
I have seen the engine of that vehicle and yes it is similar to what is shown, but the 1,3,5 cylinders are all rear (going from passenger side with 1 to 5 on the driver's side) and there is a similar amount of work involved as shown to the one with my RX300. 5 would be the back rear closest to the driver's side.
#99
#100
Super Moderator
This is getting interesting. I finally found coil 5 but was unable to get it out. Got some ideas form phlfly so will try it out tomorrow.
I put scanner today and surprisingly got P0133 instead original code of P0355. P0133 is for Oxygen sensor so now have no idea what could be wrong with the car. Any ideas?
I am still going to swap coil 5 with one of the front one's just in case (assuming I can get it out
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#102
Super Moderator
If you have a bad coil, that can sometimes throw an oxygen sensor code.
#103
If any one has any ideas on how to get the connector out please reply or will have to take it to a dealer for fix.
Thanks
#104
Super Moderator
I gave up
I could not get the cable connector out. I removed wiper blade, motor assembly, plate and engine hose. I can see the coil but it is in tight spot and was unable to remove the connector. I also tried with peak tool but not enough space to put in both hands to get it out.
Thanks
Thanks
#105
I gave up
Thanks
Thanks
You can not put your hand(s) on the connector?
Have you experimented on the front connectors to learn how to separate the connector?
You can push the release, but still can not separate the connector etc.
Salim
