dash light replacement
I read through the procedure for removing the instrument cluster to change out a bulb- it's very helpful but the only thing that was not clear is how to remove the trim panels next the the steering column (the ignition on the right, the seat memory/mirror panel on the left). Do I pull away at the top, bottom, side? I don't want to break any tabs and have to replace a panel.
Thanks
Thanks
2006, cluster, dash, dashboard, gear, instrument, lexus, light, lightlexus, replace, replacement, replacment, rx300, shift
