Complete list of CEL Codes
Hey guys. I was wondering if anyone had a list of codes and what they stand for on the RX300 or knew where i might find them? Did a search and came up blank. I have 1999 RX300. Are all the codes the same for all Lexus? thanks for the help.
John
John
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
This is a list of the codes produced by OBDII
All of which will cause the Check engine light to stay on.
P0100
MAF Malfunction
P0101
MAF Circuit Range/Performance
P0110
IAT Circuit Malfunction
P0115
ECT Circuit Malfunction
P0116
ECT Circuit Range/Performance
P0120
TP Position Sensor/Switch ‘‘A’’ Circuit Malfunction
P0121
TP Position Sensor/Switch ‘‘A’’ Circuit Range/Performance
P0125
Insufficient Coolant Temperature For Closed Loop Fuel Control
P0130
HO2S Circuit Malfunction, Bank 1 Sensor 1
P0133
HO2S Circuit Slow Response, Bank 1 Sensor 1
P0135
HO2S Heater Circuit Malfunction, Bank 1 Sensor 1
P0136
HO2S Circuit Malfunction, Bank 1 Sensor 2
P0141
HO2S Heater Circuit Malfunction, Bank 1 Sensor 2
P0150
HO2S Circuit Malfunction, Bank 2 Sensor 1
P0153
HO2S Circuit Slow Response, Bank 2 Sensor 1
P0155
HO2S Heater Circuit Malfunction, Bank 2 Sensor 1
P0156
HO2S Sensor Circuit Malfunction, Bank 2 Sensor 2
P0161
HO2S Heater Circuit Malfunction, Bank 2 Sensor 2
P0170
Fuel Trim Malfunction
P0171
System Too Lean (Fuel Trim)
P0172
System Too Rich (Fuel Trim)
P0174
System Too Lean (A/F Lean Malfunction, Bank 2)
P0175
System Too Rich (A/F Rich Malfunction, Bank 2)
P0300
Random Misfire Detected
P0301
Misfire Detected, Cylinder 1
P0302
Misfire Detected, Cylinder 2
P0303
Misfire Detected, Cylinder 3
P0304
Misfire Detected, Cylinder 4
P0305
Misfire Detected, Cylinder 5
P0306
Misfire Detected, Cylinder 6
P0307
Misfire Detected, Cylinder 7
P0308
Misfire Detected, Cylinder 8
P0325
KS 1 Circuit Malfunction
P0330
KS 2 Circuit Malfunction
P0335
CKP Sensor ‘‘A’’ Circuit Malfunction
P0340
CMP Circuit Malfunction
P0385
CKP Sensor ‘‘B’’ Circuit Malfunction
P0401
EGR Insufficient Flow
P0402
EGR Excessive Flow
P0403
EGR Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold Bank 1
P0430
Catalyst System Efficiency Below Threshold Bank 2
P0440
EVAP Emission Control System Malfunction
P0441
EVAP Emission Control System Improper Purge Flow
P0446
EVAP Emission Control System Vent Control Malfunction
P0450
EVAP Emission Control System Pressure Switch Malfunction
P0451
EVAP Control System Pressure Sensor Range/Performance
P0500
VSS Malfunction
P0505
Idle Control System Malfunction
P0510
Closed TP Switch Malfunction
P0550
Power Steering Pressure Sensor Circuit Malfunction
P1100
BARO Sensor Circuit Malfunction
P1120
Accelerator Pedal Position Sensor Circuit Malfunction
P1121
Accelerator Pedal Position Sensor Range/Performance Problem
P1125
Throttle Control Motor Circuit Malfunction
P1126
Magnetic Clutch Circuit Malfunction
P1127
ECTS Actuator Power Source Circuit Malfunction
P1128
Throttle Control Motor Lock Malfunction
P1129
Electronic Throttle Control System
P1130
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P1150
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
P1200
Fuel Pump Relay/ECU Circuit Malfunction
P1300
Igniter Circuit Malfunction (Bank 1 Or No. 1)
P1305
Igniter Circuit Malfunction, (Bank 2 Or No. 2)
P1310
Igniter Circuit Malfunction (No. 3)
P1315
Igniter Circuit Malfunction (No. 4)
P1320
Igniter Circuit Malfunction (No. 5)
P1325
Igniter Circuit Malfunction (No. 6)
P1330
Igniter Circuit Malfunction (No. 7)
P1335
CKP Sensor Circuit Malfunction During Engine Running
P1340
Igniter Circuit Malfunction (No. 8)
P1345
VVT Sensor Circuit Malfunction (Bank 1)
P1346
VVT Sensor Rang/Performance Problem (Bank 1)
P1349
VVT System Malfunction (Bank 1)
P1350
VVT Sensor Circuit Malfunction (Bank 2)
P1351
VVT Sensor Range/Performance Problem (Bank 2)
P1354
VVT System Malfunction (Bank 2)
P1400
Sub-TP Sensor Malfunction
P1401
Sub-TP Sensor Range/Performance
P1410
EGR Valve Position Sensor Circuit Malfunction
P1411
EGR Valve Position Sensor Circuit Range/Performance Malfunction
P1500
Starter Signal Circuit Malfunction
P1520
Stop Lamp Switch Malfunction
P1565
Cruise Control Main Switch Circuit Malfunction
P1566
P1600
ECM BATT Malfunction
P1605
Knock Control CPU Malfunction
P1633
ECM Malfunction (ETCS Circuit)
P1645
Body ECU Malfunction
P1656
OCV Circuit Malfunction (Bank 1)
P1663
OCV Circuit Malfunction (Bank 2)
P1780
PNP Switch Malfunction
B2785
Ignition Switch On Malfunction (Immobilizer System)
B2786
Ignition Switch Off Malfunction (Immobilizer System)
B2785
B2791
Key Unlock Warning Switch Malfunction (Immobilizer System)
B2795
Unmatch Key Code (Immobilizer System)
B2796
No Communication In Immobilizer System
B2797
Communication Malfunction No. 1 (Immobilizer System)
B2798
Communication Malfunction No. 2 (Immobilizer System)
P0100
MAF Malfunction
P0101
P0110
P0115
P0116
P0120
P0121
P0125
P0130
P0133
P0135
P0136
P0141
P0150
P0153
P0155
P0156
P0161
P0170
P0171
P0172
P0174
P0175
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0325
P0330
P0335
P0340
P0385
P0401
P0402
EGR Excessive Flow
P0403
P0420
P0430
P0440
P0441
P0446
P0450
P0451
P0500
VSS Malfunction
P0505
P0510
P0550
P1100
P1120
P1121
P1125
P1126
P1127
P1128
P1129
P1130
P1133
P1135
P1150
P1153
P1155
P1200
P1300
P1305
P1310
P1315
P1320
P1325
P1330
P1335
P1340
P1345
P1346
P1349
P1350
P1351
P1354
P1400
P1401
P1410
P1411
P1500
P1520
P1565
P1566
P1600
P1605
P1633
P1645
P1656
P1663
P1780
B2785
B2786
B2785
B2791
B2795
B2796
B2797
B2798
Super Moderator
Super Moderator
The 1130 and 1150 codes are for the A/F sensors.
One is in the front exhaust manifold just aft of the radiator which is visible when you look between the radiator and engine. The other one is accessible from beneath the car in the aft exhaust manifold. Both sensors are fairly easy to replace if you are handy with doing some of your own maintenance. There are several write-ups on the forum on replacing both sensors.
The most reasonable place to purchase the OEM sensors is amazon.com. Denso is the OEM supplier for the sensors. The Denso part number is 234-9009 and they are in the $110.00 to $130.00 price range. A Lexus dealer will charge about $330.00 for each sensor and Toyota will charge about $250.00 for each sensor.
Driving habits seem to make a lot of difference in longevity of the sensors. My wife's 2000 RX300 has a lot of short trips and both sensors went out at about 65,000 miles. Some people here on the forum are getting in excess of 100,000 miles.
Can anyone please post a picture of location of O2 sensor bank 1 sensor 1 and bank 2 sensor 1, I saw two different sensor location for this code P1155. Thanks in advance.
Mystery
RX - 1st Gen (1999-2003)
68
11-10-18 06:33 PM
