Bosal Downpipe Camry V6 ??
i remember TunedRX300 talking about the Bosal Downpipe Camry V6. i was wondering would it fit or i need to do some modifications to it.... i would like to get more info about this.
Lexmex may have better idea.
I believe you need to modify slightly for proper fitment. RX's downpipe and hops up to get around a body frame before the catalytic convertor, the camry downpipe hops down.
Super Moderator
This is the picture TunedRX300 had once posted of it,
https://www.clublexus.com/forums/sho...7&postcount=47
I think the problem (here is the area in question from my modifaction) is this area here, and you can't squeeze too much piping in there.
Probably would have to make some significant modifications here and maybe on the upper part of the downpipe close to the O2 sensors (making it a little to the left or right). Keep in mind by putting one of these things on, two precats go off. As I mentioned, I haven't had an issue wtih my Magnaflow cats, but leaving OEM Lexus cat all by itself will spell trouble for those of you in cough cough CARB land and other areas.
thank lexmex for the tip ... i see what you mean .. the picture was alot of help .. its gonna be alot of trouble to do this downpipe and your right its about the C.A.R.B.
