Is this Oil Sludge?!??!!
I was cleaning my car tonight and as a safety checkup, I wanted to make sure I had oil in the car. When I removed the oil cap, I noticed something black inside. I couldn't see through it. It's black dirt inside. Has anyone taken off their oil cap and look inside? When you change your oil, does the oil trickle into the engine? I'm scared!!! I only change my oil through the dealership and I do it every 3000 miles with them.
Help!!
Help!!
You can not see inside the engine because it is an oil baffle. There is no oil circulation so oil is cooked here. Need to pull the valve cover to check for sludge for sure.
What you see when you look into the oil filler opening is the fabric? oil baffle. Check out another RX300 at the dealer or with an RX300 owner you meet at a aparking lot if you need to be further convinced.
If you change your oil regularly (i.e., every 5,000 or less) at the dealer, from what I've read, you have virtually no chance of oil gelling.
oil gelling is so over blown, if you change your oil regularily it will not happen.
If you run cheap-o oil, run only short distances, and do a lots of towing, then you might need to worry about changing it more often.
Thanks everyone. I couldn't sleep last night so I went straight to the dealer this morning and asked them. It's some cover thing you guys are mentioning. I also checked another RX300 in the service area and he also has that cover plate. I feel so much better. My oil level is fine too. They wanted $350 just to look at it, but since I change every 3000 miles from only them, I think there is no oil/gel/sludge. Much thanks guys... That plate just looks weird. How do people who change their own oil put a funnel to pour the oil? I seeps in slowly...
A kind suggestion, you need to stop going to dealer and overpay for bulk oil. There are dealers (not sure your Lexus dealer) use recylced cheap bulk engine oil that has minimum additive package.
For the same $, I would go for Castrol Syntec 0w-30, made in Germany. Its base oil is 100% synthetic and can be bought at Autozone. Lexmex has used it and loved it.
Super Moderator
Check you oil dipstick and see if you have hard carbonized deposit on the metal stick.
A kind suggestion, you needs to stop going to dealer and overpay for bulk oil. There are dealers (not sure your Lexus dealer) uses recylced cheap bulk engine oil that has minimum additive package.
For the same $, I would go for Castrol Syntec 0w-30, made in Germany. 100% synthetic and can be bought at Autozone. Lexmex has used it and loved it.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
I also noticed mine was unusually carbon caked when I purchased my car with 80,000km and documented oil change every 6000km
Guess the bulk oil the dealers are using just doesn't cut it. You would think when someone is purchasing a premium brand and paying $100+ /hour for labour that the dealer would have the common sense of putting in something a bit better than the stuff that comes out of a steel drum... specifically when my Lexus dealer wanted $87+ per oil change.
BTW my local Toyota dealership regularly stocks Mobil 1 and will glady use it on your Lexus for the price that lexus charges for an oil change with ***** oil
Inside the oil filler area where the so-called baffle is located you should see enough clearance to hold the funnel.
I lean my funnel to the right so that the oil drains to the left in the filler area where the clearance is located.
Easier understood when looking at the part in question, than reading a post.
Not as difficult as it seams..
You might want to take your fingernail and gently scrape the top of the baffle. Mine had all kinds of crusty stuff on it (scarey to think of whats inside).
Thats why I went to synthetic oil shortly after purchasing the vehicle and added an engine flush the first couple of times prior.. to get out as many pre-existing deposits as possible.
My oil does stay cleaner (in colour) throughout the oil change intervals as a result.
