Passenger window
check out this thread. I had a similar problem.
https://www.clublexus.com/forums/sho...d.php?t=268620
in my case the rubber guide rails was causing too much friction and it tripped the overload on the motor, causing it to go down when i clicked it up and causing erratic opening as well.
I had to follow up the armor all with a dry spray lubricant. After that the window slides up and down smoothly.
