Photo DIY 4: RX300 AC/Alternator Belt Adjustment
#61
Just saw the pictures now of the straight on approach thru front of RX with extensions after my previous post. I'm thinging that is best method on the adjusting bolt. I also saw this on a YouTube where the extension comes mysteriously creeping in to turn the bolt. Had no clue on the set-up until the forum. Thanks to all!
#62
Correct Part No. for OEM Belts
I've read a lot of the complaints regarding the squeaking belts and how important it is to stick to OEM for these. Can someone list the OEM part numbers for 2001 (build date 10/00 if that matters).
#63
Quick question as the startup belt squeal lasts progressively longer now.
I want to tighten up the belt a bit.
Is it necessary to loosen up the pivot bolt or I can just go straight to loosening the adjusting lock bolt + adjusting bolt?
Margate330 (02-21-20)
#65
All binding attachments must be loose (not floppy- but loose so that the alternator can move). Then use the change in length to push the alternator away creating tension in the belt. Once the right tension is achieved lock down (per spec) each of the attachment points. Just in case you try to change the length of the tension adjustment without loosening the anchors, you will most likely break the tensioner (it is made of zinc alloy).
Once the belt starts slirpingng and not attended immediately, shine develops and the friction coefficient changes. In simple terms, just replace the belt at that time. Not worth doing the work twice .. specially if the belt has had some years.
Lot of people wing it but there is a specified tension for new and used (after 10 mins of use) on the drive belt. I have always used those numbers and never had the belt issue or bearings issue on all components the belt drives.
Salim
Salim
#66
AC pressure switch replacement
Hey gang, can anyone help me with directions on finding ac pressure switch and how to replace it properly? ‘03 RX300 — is there anything on YouTube y’all suggest I follow? Thanks guys
#67
A lot of you seem to be having problems with accessing the bolts or nuts in close spaces and turning them. I have a easy solution, I am sure all of you just like myself have been getting cheap tool sets for years from the family or friends and have spare sockets and socket wrenches. Here's what you do, take a old or never used 1/4 3/8 1/2 or the whole set of three and cut the handle off about 3/4 a inch from where the head stops with a grinder then smooth the mini shank that's left with grinder/file/sander to remove burrs and presto easy 3 piece set of mini finger wrenches.
#68
Help with putting alternator back on
I could really use some help. I'm replacing my alternator. So far I have the old one out and the new one kind of in but I have 2 bolts in the back and I'm not sure how those go. There doesn't seem to be a place for the second one to go.im on my own here and have to do things myself so any help would be greatly appreciated.
#69
That adjusting bolt is a pain. There aren't any great pictures in this thread because it is a miserable spot to work in
First, did you carefully compare the pully on the alternator that came out with the one you are putting in? There are two models with different pully sizes
This one is 58mm https://shop.advanceautoparts.com/p/...56a/19850518-P
This one is 65mm https://shop.advanceautoparts.com/p/...44a/15850007-P
Put the alternator in place.
Put the top pivot bolt in.
Put the belt on
With one hand pull the alternator up as far as it will go.
With your other two baby size hands get that block into place, feed the fastening bolt through the alternator, and wiggle things around until the bolt finds the bolt hole.
Finger tighten the bolt, then use the adjusting screw to adjust the belt tension.
Then tighten the fastening bolt
Good luck. I hate that task. But I think I made it worse my previous time using the bigger pulley size. I do not know if it is always ok to use the smaller one.
Put the belt on
#70
Put the belt on
Put the belt on
#71
hey it's me and I dont know how to reply to you so I hit quote. Anyway the. Stupid guy at eurozone tried to give me a 80 amp alternator that was smaller then mine both manager and employee tried to make me believe that 80 amps was enough to run my electrical. I finally told them I wasn't buying it and then a spark must have fired in the managers brain and he asked if I had an Es. I have an rx300 1999. Anyway I had the old one with me and compared them to make sure. Ok I'm getting back to it. If i had an extra set of hands i could have done it by now.
#72
I tried I just don't have the strength to hold it up while trying to, blindly, find the hole it goes into. I have been trying to do this since 7:30 this motning and i just cant get it to line up enough to get the bolt in. Anybody here live near lake city florida? I wonder if i can maybe pull it up and prop something under it. Humm I'll try that.
Salim
#73
You must be fighting something which you should not be. Make sure the adjustment bolt is turned to give you maximum play. Do not put the belt on and loosely mount the alternator with the two fasteners. The alternator at this time should have plenty of movement. Make sure you have the right belt and put that on (you may have to hold the alternator as you ry to thread the belt. Once the belt is on, gently tighten the two fasteners to remove the slop, but they should be loose to allow the movement to take-up belt slack. Now spin the tensioner .. use the hole by the radiator if you have long ratchet attachment. Once you get the right tension, torque down the two fasters and lock up the tensioner.
Salim
Salim
If I could it would have been a lot easier.
#74
Salim
Salim
#75
I've did everything, I have loosened it, taken it off, tightened it up. I tried to prop the alternator up with a rock, I yelled at it prayed for it and even sat on the ground and cried to it and still I can't match them up. This is crazy If it wasn't for that stupid bolt I would be driving again. And as far as whoever designed this **** to where even a woman's hands don't fit needs to be hung.
