Caliper Mounting Bracket Bolt Torque Spec?
Old 03-26-07, 09:35 AM
tuxlexus
tuxlexus's Avatar
Default Caliper Mounting Bracket Bolt Torque Spec?
I just started the brake and rotor job and realized that I don't have the the torque spec for the caliper mounting bracket bolts. I need to remove the bracket to replace the rotors. Many thanks if anyone can provide the spec for the front and rear caliper bracket mounting bolt torque spec.
Thank you,
-Johnny
Old 03-26-07, 12:51 PM
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
25 ft-lb for the center piece.
The large outer piece bolts are 79ft-lb
Hose hoold down 29ft-lb
Hose union bolt 21ft-lb
Slider pins (bolts) are 25ft-lb
Salim
[7,6]
Old 03-26-07, 03:31 PM
tuxlexus
tuxlexus's Avatar
Thanks.
I jsu tfinished the job though. For the caliper mounting bracket bolt I just ratched until it is tight and then gave some extra push.
The rest I had the spec.
Thanks to everyone here I got it done. The toughest part of the job is rust, rust, and more rust in parts.
Salim
[7,6]
SGLexus
07-17-23 11:39 PM
IceIridium
IS F (2008-2014)
07-27-18 12:13 PM
r3dl4b3l
14
02-25-18 09:03 PM
jimsdrx200
02-03-16 02:40 PM
350PsDMeuP
Suspension and Brakes
24
10-25-08 05:00 PM
Quick Reply: Caliper Mounting Bracket Bolt Torque Spec?
