rattling noise and check engine light
before i got my custom exhaust setup my 99 rx was making a rattling noise whenever the engine is on. i learned to live with this noise, but when i reset my battery, for performance reasons, a check engine light will come on after a couple of miles. Usually the P0171. i would then reset my battery again and the code wouldnt pop up again.
during my exhaust install i mentioned the rattling noise to the guy making my system and he said he also noticed the noise when i pulled up on the lift. when he looked at the area where the noise was coming from he saw that my precat was cracked. for a quick fix he welded it shut and the rattling went away, but he did tell me to have it replaced.
i reseted my battery again a couple of days ago (for the new exhaust) and now the check engine light came on.
i just now disconnected the pos and neg on the battery and going to leave it unpluged the whole night. hopefully the ecu will overlook the problem like the past.
can i just use a universal free flow cat as my precat or do i have go to the lexus dealership? Or is there a oem toyota precat part that will fit on the rx300, but is really meant for a highlander or camry?
thanks!!!!
thanks!!!!
Exhaust plumbing may be slightly different between RX and Camry. I believe federal emission warranty covers cats for 8 years, are you still under that warranty or is it just a California thing?
Super Moderator
1MZFE engine should be similar to the Highlander as they had similar power in their engines, but as TunedRX300 mentioned Camry is slightly different.
I also found myself welding parts here and there on the exhaust before I did those downpipe modifications. Some Solara owners, that also use a 1MZFE on the 3.0 model, do not have OEM precats. Just depended on what part of the country the vehicle was sold in. However, I am 99.9% sure all OEM RX300s had them in North America.
Super Moderator
If you put straight pipe on the precats, the stock OEM cat is not sufficient to pass emissions test (at least not where I live), but if you get one of the Magnaflow cats like I have (see page 3 on my site below), these are 3 way cats and will do the job.
i think ima go buy a toyota precat and replace it myself. it looks like it might cost more if i make both the precats a pipe and putting on a magnaflow cat.
found the one i need for $264.95. it looks like its just bolts so i could probably just do it myself.
http://replacement.***************/par...howdc=true#top
