How to stiffen suspension?
Does anyone know if there is any way to stiffen the suspension on a 2000 RX-300? Every time I make a quick turn there is so much body roll. On my Acura, I put in thicker sway bars to reduce this body roll and loved the difference. Does anyone make sway bars for our RX? Or is there another way to make the suspension stiffer?
Thanks,
Peter.
Thanks,
Peter.
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
Yea, ok Yoda.
Know the difference between sprung and un-sprung weight on a vehicle? I'm sure you do, the same way you finally got a clue what the viscous coupling is used for on the 4wd transfer case.
Pitiful.
Pitiful.
Still more useless info from wild *****. The original point was to reduce body roll. "Every time I make a quick turn there is so much body roll. On my Acura, I put in thicker sway bars to reduce this body roll and loved the difference."
Petrie inadvertently asked to stiffen the suspension afterwards, changing the stiffness of the tires will not do much to reduce body roll, but will affect handling response. The tires/wheels are part of the unsprung components of the vehicle.
As Petrie already indicated, one solution is a stiffer sway bar. Another solution is to change the characteristics of the springs and struts (which is what a Silver Sport edition does).
Here's an idea:
http://www.tte.de/tuning/website/Acc...ring%20Springs
http://shop.store.yahoo.com/racinglab/lux98rxeibsp.html
Hope this helps,
TC
Here's an idea:
Hope this helps,
TC
"petrie inadvertantly asked to stiffen the suspension afterwards...."
Oh, now I get it, you're criticizing ME for my lack of mind reading skills, why didn't you say so right at the begnning and leave it at that?
"Too much body roll", that's pretty much how I would have (inadvertantly, incorrectly{?}) described my first Lexus, a 92 LS with 15" OEM wheels. TC, I would swear in a court of law today that upgrading that car to 16" wheels and wider tread tires helped remove enough of that "pit of the stomach queasiness" that I would have mis-interpreted as body roll, that both my wife and I became much more enamored with the car.
In our "stable" at the time was an 85 Jeep Cherokee and a 78 911, so we had no good "standard" for comparison when we purchased the 92.
But, the question is, what does petrie think about all of this, are we both trying to be constructive and helpful?
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
I don't really have a dog in this fight, but I would point out that a wider stance could be thought of as creating a lower roll center, thereby decreasing body roll at a given yaw (turning) rate.
MT-
To a certain degree you're right, but not on the bullseye. Don't forget that the part of the vehcile that is rolling the most is the body, or basically all the parts of the vehicle above the suspension system. That's the trade-off for a comfy, compliant ride.
You could make the wheels infinitely wide-- but you still have the inertia of the sprung weight when going into the curves. Using your wider-stance on the wheels just means that the wheels will want to go one way (track the curve) and everything above them will want to go another way (tangent to the curve). Don't get me wrong, the wider tire stance does help some in handling, but doesn't attack the root cause of the problem (body roll).
Changing the characteristics of the springs or a anti-sway bar forces the sprung weight of the vehicle to more closely follow what the wheels are doing.
A time when I was being towed (my 92 Jeep) behind a PU with big ballon "mud" tires. I remember watching him from behind and coming to the realization that most of his "body roll" was the result of all of the flexing of those tires.
When we arrived at our destination, I had told him which driveway to turn into, but it appeared to me he was going to overshoot to the next driveway so I started steering the Jeep to the left, "pulling" him left to "wake" him, or give him a heads up.
I remember thinking oops, I can't do this, as I watched the treads of those balloon tires roll under as the huge sidewalls "wallowing" due to my "moment" on the PU body.
Maybe 1" lower sidewalls don't help very much, but they do help.
RX 300 & 350Z Guru
I'll have to agree with TC on this on, 100%. The logic is not hard to follow. Change the wheel and tire combo and all you have is tires that take the weight of the vehicle with less flex - there is still just as much body roll. All you're doing is changing the driving dynamics below the suspension - it's unsprung...doesn't help body roll.
*****, why can't you just admit you were wrong about something, in one way or another?
-Nick
-Nick
Originally posted by LexRX
....*****, why can't you just admit you were wrong about something, in one way or another?
-Nick
-Nick
"Every time I make a quick turn there is so much body roll."
TC, LexRX,
So, tell me, just how do you guys, setting in the drivers seat during a quick turn, tell the difference between "body roll" and tire sidewall "compression" on the outside of the turn and "lift" on the inside?
Lean out the window and have a look?
TC, LexRX,
