Rear wiper problem
Hi all, just got an '01 RX AWD and so far I'm loving it. I have a few things to fix, some of them seem to be common problems and I was able to find them on the search, others I wasn't. Here is one I couldn't find. Hope you guys can help:
The rear wiper does not work well. When it works, it works continuously, even on the intermittent option. When I turn it off, the wiper arms just stops wherever it was. Other times, when i turn it on, it just doesn't move. I don't think it's the motor, but some sort of sensor or "actuator"? Any ideas what this might be.
TIA
TIA
It seems like that it is the motor ...
Wiper motor has a contact (like a parallel switch) which only shuts of the dc power when the arm is reaches the rest position [unless you turn the ignition key of].
Salim
Salim
