Install gasket when renstalling oil drain plug?
Super Moderator
Here is the filter on mine, it is an HP-1002, which is used across several Lexus/Toyota products.
I always get a crush washer in the box with a new Toyota oil filter.
The local Toyota dealer even gives me a 10% discount.
Just a reminder...
ALWAYS look on the drain plug or the oil pan for the crush washer... You don't want to install a new crush wash over an existing one as this will guarantee leaks
Rotated the position of the horn in the engine bay and remove and re-install my toyota filters from the top and don't have to raise the car.
15 minute oil changes (not including another 10 minutes to let the engine cool down after draining or
on the forearms)
Just a reminder...
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I reuse the gasket over and over again, not a single drop of oil leaked from the drain plug.
