What causes these codes? P0440, P0441, P0446
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
you were on spot with the disconnected vacuum line, several weeks ago i checked the air filter and must of loosened the line, just connected it and going to take a drive for a beer, hope it's gone while i'm driving, don't want to disconnect the battery now, i am hoping it'll reset itself in 15 mins, should be enough time for me to drink 2 bottles of bass ale thanks much for your knowledge
Did you get that fixed? i have the same problem, i changed out my spark plugs and got those 3 codes with the tapping sound. i'm going to re tighten the spark plugs just in case one got loose. any advise will help. thanks
berto527 (12-20-17)
I've had the same code P0446 for months now and i just clear it from time to time. I also get a exhaust type carbon smell from the engine bay that comes and goes. Could that be a catalytic converter going bad or clogged? My mechanic says the same thing that its the charcoal canister in relation to the code that pops up.
tmf2004 (08-08-18)
