Sun/Moon Roof Sound
Hey guys the weather is finally nice here in NJ and the Sun/Moon roof will be in use more offten now. When its opened (tilted) up it makes like a crakling sound coming from the mecanism. Needs to be lubed? Lithium grease?, If so where exactly do I Lube? Does not make any sound when opening or closing, just when its opened and stays opened. Wondering if anyone has had this craking sound. Thanks
--Yosh
--Yosh
This was a common problem a few years ago. I know we discussed it on the online forums but I am not sure which ones. I am not even sure if Club Lexus was around then. You can try a search. I'm pretty sure Lexus even had a TSB on it. It has to do with the plastic sunroof trim expanding and contracting. If you park the car in the sun and then drive with the A/C on you will hear the cracking as the plastic contracts. Early on, I had my 2001 back to the dealer a few times for this. This was before lexus identified the problem. They did help it but I can still hear it sometimes when the above conditions are met.
--Yosh
--Yosh
https://www.clublexus.com/forums/sho...light=clicking
Here's a link to a discussion we had on this back in 2001.
Fizzboy7
01-16-23 10:19 AM
