Air Mix Servo???
#91
https://www.clublexus.com/forums/gs-...vo-motors.html Heres the DIY
when I click on this link in post #32?
What privileges does it require?
#92
Why do I receive error saying "Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?"
pasting it for you. try copy-paste into your browser instead of hyper link.
https://www.clublexus.com/forums/the...vo-motors.html
The above got converted too hyperlink. Copy paste from my reason to edit.
Search our DIY sticky thread too.
Salim
Last edited by salimshah; 07-21-19 at 02:59 PM. Reason: https://www.clublexus.com/forums/the-holding-tank/399744-diy-on-changing-servo-motors.html
#93
What I used on the lower servo on the hard to get at screw was the same thing I often use, that's a #1 on the #2 screw. That allows you to get at a greater angle and yet keep the bit in the the screw. What I used on the upper servo (I believe) was a stubby Phillips bit and a 1/4 in. ratcheting box end wrench. I actually have a really stubby 1/4 in. Phillips bit that I ground down to only the Phillips and enough of the hex to hold in the ratcheting box for those REALLY tight places. A sharp #1 will actually hold quite well on an angle where a #2 will want to slip if the screw is not excessively tight.
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/176x272/offset_screwdriver_3_59_d036f374d2f5fc90d6fbb1cca5088a9609f8c7f2.jpg)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/357x200/neiko_01323a_ultra_low_profile_offset_screwdriver_set_10_99_d44fbdc2e2b87a4f82e936e6b5cf9dfaf68687d8.jpg)
What I don't get is why is hot water running through the aluminum pipes and heating core all the time. It should only be routed here if heating is selected.
#94
Or this
https://www.harborfreight.com/8-piec...ver-92630.html
I have the set similar to ACE but that one does not allow me to keep enough downward pressure to engage the Phillips head. HF one allows me to push the head down with one hand and use the second to do the ratchet action.
Salim
Salim
