where is vacuum line for 99 Rx300, i want to use seafoam
Old 05-13-07, 02:29 PM
cuda
cuda's Avatar
Default where is vacuum line for 99 Rx300, i want to use seafoam
I want to use seafoam to clean my 99 Rx300, but I can't find vacuum line.
Old 05-13-07, 07:07 PM
Lexmex
Super Moderator
Lexmex's Avatar
And a very similar Toyota engine, too. http://www.youtube.com/watch?v=SZf4WXwVL_E
In the RX300, you want to shoot it through the PCV valve area. There is a hose in a location similar to what this guy shows on the left side as show in my photo below (what I am holding in my hand you want to pull it off the PCV valve below).
Attached Thumbnails where is vacuum line for 99 Rx300, i want to use seafoam-img_2042.jpg
Old 05-14-07, 06:31 AM
cuda
cuda's Avatar
Thanks so much, I will try this weekend.
Old 05-14-07, 07:50 AM
edbro
edbro's Avatar
Lexmex,
Just so I am absolutely clear, you pull the hose from the end that is at the bottom of the picture under that round part, not the end that is at the top of the picture?
Old 05-14-07, 07:59 AM
Lexmex
Super Moderator
Lexmex's Avatar
Originally Posted by edbro
Lexmex,
You pull it from this point on the PCV valve. You then need to attach a funnel on this end to it to pour the Seafoam (or whatever else) in.
Attached Thumbnails where is vacuum line for 99 Rx300, i want to use seafoam-pcv.jpg
Old 05-14-07, 08:05 AM
edbro
edbro's Avatar
Thank you. If that's a vacuum line won't it suck up the Seafoam instead of having to pour it in?
Old 05-14-07, 08:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
When you pull this hose off, the engine can stutter a little, so pouring it in this way will help it take in the seafoam.
Old 05-15-07, 12:02 PM
tcheung87
tcheung87's Avatar
Hey Lexmex, how hard is it to pull off the PCV valve? I gave it some good tugs today and it wouldn't budge, I have the seafoam ready =)
Old 05-15-07, 04:55 PM
Lexmex
Super Moderator
Lexmex's Avatar
I should apologize as I have a hunch why. The 2001-03 RX300s have a different PCV valve setup that is a metal/brass. There was a photo a while back that I could not find. In both cases, all you have to do is get the hose off of the PCV valve, the PCV valve can stay put.
Old 05-16-07, 07:44 PM
LiqrSicc
LiqrSicc's Avatar
hey guys, sorry, I'm completely clueless when it comes to this. What does the seafoam do and what is the vacuum line for?
Old 05-16-07, 08:33 PM
Lexmex
Super Moderator
Lexmex's Avatar
Well the lines I am referring to are ones that remove the crankcase gases and shoot them back into the combustion cycle.
As a result of this process, your intake manifold can get yucky and disgusting with oily crud.
Seafoam is a product that can help remove this kind of stuff like carb cleaner, though more efficient. Seafoam has some other good properties in the oil and gas, but the use through the intake mainfold is the main use of it.
minorkeyle
08-11-16 09:42 AM
reisjdmd
03-02-13 06:16 AM
daxman1
09-24-07 03:28 PM
RayN
09-10-07 10:59 AM
Quick Reply: where is vacuum line for 99 Rx300, i want to use seafoam
